Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
central locking key fob problem
LinkBack Thread Tools Search this Thread
Old 01-03-2010, 09:08 AM
neemo's Avatar
Default central locking key fob problem
Hi all
im Neemo and new to the Forum
i purchased an 1996 XK8 yesterday, and the car has some minor faults.
firstly is the drivers window dropping in stages and not comming back up
due to this brilliant forum ive found out how to repair it
but my main problem is the remote fob/central locking.
the central locking is very intermittent
the unlock button works and so does the light and remote boot/trunk button
but the car wont lock on the lock button
it has worked maybe 2 out of 10 times
also the car will not lock with the key, if i try to lock it with the key the alarm sounds?
can anyone help please
Old 01-03-2010, 09:56 AM
Gus's Avatar
Gus Gus is online now
gus@jagrepair.com
Send a message via Skype™ to Gus
I have little or no experience in this area but will give you my input. If it were just the remote cleaning it may help. You can go to my page and to the left you will see Jag xk8 remote click on it and you will see what I found and how to clean it. As for the key locking setting off the alarm I would check that all switches related to the security system were working properly. It seems to me if one were not open or closed to satisfy the security system it will do what it is doing to you.
__________________
Gus
www.jagrepair.com
XK8 1999 130,000mi K&N Filter, S-Type 2000 3.0 120,000mi K&N Filter
“If you can't dazzle them with brilliance, baffle them with bullshit.”― W.C. Fields
Insanity: doing the same thing over and over again and expecting different results.-Albert Einstein
“I fear the day that technology will surpass our human interaction. The world will have a generation of IDIOTS.” – Albert Einstein
Old 01-03-2010, 02:06 PM
H20boy's Avatar
door latch assembly replacement are common to these cars, perhaps related...
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 01-03-2010, 05:35 PM
OregonJag's Avatar
..what Gus said.
Cleaning the remote on the inside makes a big difference. You'll probably find a big blob of oily substance under the lock button. It did make a difference in mine anyway. Don't expect these remotes to have any range. They're like my '96 pickup, you've got to be almost on top of the vehicle for them to work. I suspect later years were much better.
__________________
'97 XK8 roaming the Pacific Northwet daily. 192k miles....
.. hey the sun's out . . . . .
Close the umbrellas and open the top! ...
Uh-oh, the rain's coming back ...
Old 01-03-2010, 05:39 PM
neemo's Avatar
cheers for the tips Gents
ill strip it down tomorrow
thanks.
Old 01-03-2010, 07:33 PM
Gus's Avatar
gus@jagrepair.com
For what it is worth and I have no idea why I get better range when I hold the remote vertically and pressing the button.
__________________
Gus
www.jagrepair.com
Old 01-03-2010, 07:43 PM
OregonJag's Avatar
Curious, will your key in the door-lock-cylinder lower the windows and top if you hold it in the position to the right (clockwise)? You should be able to raise and lower the top with the key in the door. Clockwise lowers, counter clockwise raises the top. It takes a while to go through all the steps, be patient.
Also, when you step out of the car and the window has lost its memory..again, use the key to raise it by turning counter clockwise. There is a couple of seconds delay before it acts.
This all assumes it doesn't set of the alarm again.
Good luck. I've learned a good bit about my car in the two months I've had my '97.
Mike
__________________
Old 01-04-2010, 06:03 PM
@Gus:
Use capacitive coupling to increase the range of your remote keyfob. As documented by the New Scientist article, place your remote under your chin (or any other body part) and push the button to increase its range.
http://web.archive.org/web/200406031...e.jsp?id=lw962
Old 01-04-2010, 06:56 PM
How about your hand?
__________________
North Georgia SPRING 2015 Trout and Cars http://www.jaguarforums.com/forum/us...1/#post1184744
2002 XK8
2001 Honda GL1800A
1982 Volvo 245 Ford 302 V8 http://forums.turbobricks.com/showthread.php?t=250257
1981 Volvo Bertone Coupe - 25k original miles http://forums.turbobricks.com/showthread.php?t=256460
Old 01-04-2010, 07:01 PM
Not sure of the specifics, but after reading the article, I gather that the conductive material in your hand is minimal compared to your head/torso so the amplification of the RF signal would be minimal... try it under your chin.. it really works!
Old 01-04-2010, 07:20 PM
Gus's Avatar
gus@jagrepair.com
So what you are saying is that if I stick my remote up my A__ it will work better?????? Only kidding! Only Kidding!!
__________________
Gus
www.jagrepair.com
Old 01-05-2010, 07:22 PM
hlgeorge's Avatar
Let us know how it works Gus!!?? Not kidding!
__________________
Lew
2012 Jaguar XF (Claret/Barley)
[Upgrades: Chrome side vents, red wheel center discs, LEDs: tag, boot and all interior lights.]
2011 Nissan LEAF (Cayenne Red/Light Grey)
2004 Jaguar XJ8 (Seafrost/Sand) (Sold 10/17/12)
2001 Jaguar XKR Conv (Platinum/Oatmeal) (Sold 10/10/12)
Old 01-06-2010, 09:25 AM
Gus's Avatar
gus@jagrepair.com
Ouch!!
__________________
Gus
www.jagrepair.com
Old 01-10-2010, 07:29 AM
I posted a solution to the original problem of intermittent key fob in the XJR forum.
Old 01-12-2010, 03:55 PM
neemo's Avatar
Cafepombo your a star
what i had to do was retrace the curcuit board
and its working a dream
cheers
Old 08-14-2012, 10:23 AM
Smile Brilliant
May be an old post but its just saved my bacon & sorted my key fob out a treat, take it apart and give it a clean, dirty black gunk under the buttons!! Its never worked better....cheers guys!!
Old 08-14-2012, 12:49 PM
Yep, some alcohol and Q-tips can work magic with these grungy key fob innards. Had to change the battery in my S-Type key fob just an hour or so ago. While I had it apart for the battery change, I gave it a decent cleaning....
__________________
2005 S-Type 3.0, Quartz / Dove
2006 XK8 Victory Edition Convertible, Onyx / Cashmere
Raleigh, North Carolina
Old 08-14-2012, 06:18 PM
Gus's Avatar
gus@jagrepair.com
See if this link helps the next person
Link: JagRepair.com - Jaguar Repair Information Resource
__________________
Gus
www.jagrepair.com
Tags
1995, 1996, 1999, button, central, code, fob, jaguar, key, locking, problem, problems, push, trunk, unlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
