Convertible top hose placement
Old 06-27-2013, 07:51 PM
monster48's Avatar
Default Convertible top hose placement
Just replaced all 4 top hoses to my rams...may have screwed up does anyone know if the bottom hoses on the rams go to the top or bottom fittings on the pump...worked one time and now will not work I have my bottom hoses on the bottom fittings of the pump. I my have the hoses reversed
bought my replacement hoses from Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc great hoses and service 2003 XKR
Old 06-27-2013, 08:26 PM
SteveJacks's Avatar
If the top latch doesn't drop out of the way with the top down, then they are reversed.
Old 06-27-2013, 09:04 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
This should help!
Check your connections and see what problems you might have then.
Old 06-28-2013, 02:34 AM
batroute's Avatar
I think there is a schematic on Gus's website but if not the lift cylinder bottom hoses go to the top fittings on the pump and the top ones to the lower fittings.
Old 06-28-2013, 06:04 AM
monster48's Avatar
Thanks ...I have them on the wrong connections will change and let you know the outcome.
Old 06-28-2013, 06:50 AM
monster48's Avatar
Changed hoses around....top went up and down one time and now will not operate. Rear windows go down but will not come up. seems to not be getting any power at the pump. getting hood not latched signal. pump not running.
Old 06-28-2013, 07:11 AM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
How is your fluid level?...it may get too low as air is displaced. Is the petcock fully clockwise?
Manually override the pump (petcock counter-clockwise), latch the top, put it back to automatic (petcock clockwise) and try again.
Old 06-28-2013, 07:40 AM
monster48's Avatar
Got it working. I had the wires crossed on the right cylinder. now everything is out of sink. top goes down when you hit the up button and front latch is not working right. back window still not working . How do I get everything back in-sink?
Old 06-28-2013, 07:45 AM
WhiteXKR's Avatar
It sounds more like something is crossed now.
In any event, to reset follow the instructions I gave above "Manually override the pump (petcock counter-clockwise), latch the top, put it back to automatic (petcock clockwise) and try again."
Old 06-28-2013, 08:39 AM
batroute's Avatar
When I did my cylinder hoses it took 5 or 6 attempts to purge the air from the system - it would get half way up then collapse down again due to air pockets but I made sure to keep cycling the system up until it latched correctly - perhaps if you have pressed the down button the system is confused and out of sync. Try a hard reset then raising the roof again - also, as stated, make sure the fluid level stays within limits.
Old 06-28-2013, 10:31 AM
monster48's Avatar
still no luck..when I press the down button the top wants to go up. stops half way. have put the top up manually when I press the down button top lack only unlatches half way
Old 06-28-2013, 10:52 AM
WhiteXKR's Avatar
Double check your hydraulic connections against the attached diagram.
If you have been working without the engine running, your battery may be getting low, this can also cause a stall.
File Type: pdf
Old 06-28-2013, 01:23 PM
Gus's Avatar
Gus
Gus is offline
It could be that your top is confused! Open the petcock open the roof manually check that the rear windows are open and that the lock is stowed then close the petcock, check the fluid level and do a hard reset. At this time close the roof electrically and hold the button until it is completed. The roof may run slowly and it may take time to operate because of air presented to the system. I should mention that this system will self purge.
Old 06-28-2013, 04:57 PM
monster48's Avatar
thank for all the suggestions ,the top is not as confused as i am. Calling it a night Things are still not working in sink, will try aging tomorrow and let you know the outcome rear windows will not go up on there one I have to use the breakers in the trunk. Front latch only opens half way the finally will open afere playing with the switch. I need a magic wand.
Old 06-28-2013, 09:05 PM
Gus's Avatar
Gus
Gus is offline
The rear windows will only close when the rams are fully extended and the front latch is closed! Did you disconnect the leads to the switches on the right rear ram when you changed the hoses? Check and see if they are still connected you have one on the top and another at the bottom.
monster48 (06-30-2013)
Old 06-29-2013, 08:55 AM
monster48's Avatar
Thanks...I did replace the connections on the rams. Haybe the switch on the ram is bad. they did go up once with the top switch. When I press the up button the top goes down (sometimes) When you say a HARD reset do you mean removing the battery cables and touching them together? Is it possible that the hoses are crossed. I have them on according to the diagram maybe my pump is different. will it damage anything if I switch them?
Old 06-29-2013, 09:49 AM
Gus's Avatar
Gus
Gus is offline
Check your PM
Old 06-29-2013, 12:00 PM
monster48's Avatar
Mystery solved. Had the hoses from the rams on the wrong fittings at the pump. Top hose from the rams goes to the top fittings on the pump. Thanks to Gus for all his help. Now on to the airbag light (its on) Perfect ragtop day
The following 2 users liked this post by monster48:
Gus (06-29-2013), Norri (06-29-2013)
Old 06-29-2013, 12:03 PM
Received 6,242 Likes on 5,443 Posts
Thanks for the update and good to know you got it sorted.
Old 06-29-2013, 12:39 PM
Gus's Avatar
Gus
Gus is offline
I will be removing that info from my page. I will be correcting that info for others to use soon.
Quick Reply: Convertible top hose placement
