Correct tire pressure for 20" wheel?
Old 12-06-2010, 04:56 PM
edtexas's Avatar
Default Correct tire pressure for 20" wheel?
Called a few dealers around the country today for psi info on a new set of tires on 20" Montreal wheels.
I got quite the range, from 30 to 38psi.
The most common one I got (four dealers) was 30psi on the front and 32psi on the rear. This seems a little low, but what do I know?
This is for a 2003 xkr convt.
Any thoughts or input on this? I'd like them to last. Thanks for your help.
Old 12-06-2010, 05:04 PM
SeismicGuy's Avatar
There should be a tag on the inside of the center console top that lists tire pressures for a variety of wheel/tire sizes. In my 2005 XKR, I believe the pressure recommended for the 20" wheels with the Pirelli tires is about 32 psi in front and 30 psi in rear. I typically try to keep all tires at about 32 psi (I also have the 20" Montreal wheels).
Doug
Old 12-06-2010, 05:06 PM
r0m8470's Avatar
I put both front and rear at 32 psi. If you go to the Jag USA website - there's a pdf document there - forgot what it's called - that specify the tire pressure.
Mine also have 20" and Montreals.
Old 12-06-2010, 05:07 PM
RCSign's Avatar
Ed
My manual says 32 front and 30 back on 20" BBS Detroits. I had to take a look at my manual again and it reads what MarcB listed from the Jag Spec 32 front 30 rear. So I stand corrected
Doug
2001 XKR Silverstone
Old 12-06-2010, 05:35 PM
MarcB's Avatar
From the Jaguar Vehicle specifications:
Tire Pressures (Original Equipment)
XK: 2000 MY onwards
Normal:
speeds above 100 mph
17 inch F (32) R (34)
18 inch F (32) R (34)
19 inch F (32) R (34)
20 inch F (32) R (30)
Comfort:
speeds below 100 mph
17 inch F (26) R (28)
18 inch F (26) R (28)
Maximum Speed
50 mph
3.5 x 18 and 4 x 18 inch
(temporary spare wheel) (60)
edtexas (12-07-2010)
Old 12-07-2010, 12:13 AM
edtexas's Avatar
Thanks to all, especially you, Marc B. You guys really know your stuff.... Ed.
Old 08-01-2020, 09:36 PM
Craig Mason's Avatar
Just bought an XKR with these 20 inch wheels. I spent a couple minutes looking at them but can't figure where I would add air. I'm sure it's rather obvious but any help here?
Old 08-01-2020, 10:21 PM
baxtor's Avatar
Received 1,122 Likes on 730 Posts
one of your centre spider to rim retaining bolts will have a slotted head cap while all the other fasteners will be spline head ( similar to torx)
Remove that cap and screw in your separate valve assembly. If you do not have a valve assy. You will need to get one.
Old 08-02-2020, 01:50 PM
XK Owen's Avatar
First time I tried to inflate my tyres was a disaster too
toronadomike
08-07-2022 03:41 PM
dsnyder586
04-04-2019 02:38 PM
Doug
02-27-2019 01:31 AM
Bones
09-08-2015 08:34 PM
Whitnessmouse
09-04-2015 11:09 AM
Quick Reply: Correct tire pressure for 20" wheel?
