Details on Win7 64 bit new install method & new JTIS21 XK series archive
Old 02-05-2013, 09:51 PM
Jag#4's Avatar
I finally pulled out the old PC laptop (normally I use a mac) and downloaded the JTIS files (for XK only). Everything went OK and I got the successful install message. I found the JTIS exe application in my folder and fired it up.
I can run the application and the main screen comes up, but when I click on the Service icon to select model and year I get the following error: "JJTIS MFC Application has stopped working." This is a Microsoft error (aren't they all?) that only allows me to close the program.
I am trying to run this on an Acer Intel dual pentium with Vista 32.
Did I do something wrong or have I missed a step? I'm rusty on PC platforms, so that doesn't improve things. Any help is appreciated.
  #42
Old 02-06-2013, 05:30 AM
thebiglad's Avatar
Originally Posted by oyster
Hi.
You can download Jaguar Electronic Parts Catalog (JEPC). Do a search or look in sticky section.
IDS stands for Itegrated Diagnostic System. This is a fairly complicated issue with lots of changes and upgrades through the years. To make it simpel you can buy a cheap OBD II (On Board Diagnostics) reader, plug it into your car and read generic failure codes which again can be decoded from a list in your JTIS. To get Jaguar specific codes you will need a system that is way too expensive to most of us.
Hi OYSTER and thank you very much.
I now have JTIS & JEPC working on my 32-bit Vista machine so I'm very chuffed.
The next step for me is to get a Mongoose or similar cable and software so I can now talk to my cars' systems.
I would like to thank all those members who helped me to get these systems to work on my machine - it is much appreciated.
Maybe now I'm sufficiently tooled up to give back some help to others.
Dave
  #43
Old 02-06-2013, 06:34 AM
jimlombardi's Avatar
Received 1,618 Likes on 874 Posts
Hi Mike
I have seen this issue before.
Looks like you have not registered the dao350.dll.
I purposely skipped registering the dao350.dll to see what would happen.
I ran the setup.exe in the jtis21 folder and rebooted the PC.
When the PC finished the restart, I ran the JTIS shortcut. When I tried the Service menu for model selection I had the following results:
there were no models listed and there was this popup error message
"JJTIS MFC Applicaion has stopped working"
"A problem caused the program to stop working correctly"
"Windows will close the program and notify you if a solution is available."
Dave
Look at post# 36 - you need to follow the instructions for Vista 32 operating system to register the dao350.dll.
Looks like that is the only part of the install that you need to do.
The dao350.dll file is contained in the JTIS21 archive files you downloaded.
It is in the JTIS destination folder you used during the part1.exe (extraction process).
Summary of what you need to do:
Disable the UAC User Account Control
follow the other steps, reboot PC, create C:\DAO folder, copy dao350.dll to C:/DAO folder, register da0350.dll
After you successfully register da0350.dll, reboot PC and you should be good to go.
Jim Lombardi
Jag#4 (02-06-2013)
  #44
Old 02-06-2013, 10:19 AM
Jag#4's Avatar
Thanks for the reply Jim. I will try that tonight and see if it fixes the problem.
Still wish I could use the Mac without running a virtual MS partition.
That fixed it. Everything seems to be working, although the manual was clearly designed by the same engineers who built the cars...it's not very intuitive, but useful once you get the hang of it.
jimlombardi (02-06-2013)
  #45
Old 03-15-2013, 03:45 PM
I put the JTIS archive files up on my dropbox account. I have had no problems with the downloads on the dropbox.com site.
When the dropbox webpage opens, just click on the download button and use the run option on the popup.
Here are the weblinks to the all models (JTIS21) archives files.
Part1.exe is 190 mb (195313 kb)
https://www.dropbox.com/s/fvdg6rsl63...20CD.part1.exe
Part2.rar is 190 mb (195313 kb)
https://www.dropbox.com/s/bwx4uch8m9...20CD.part2.rar
Part3.rar is 58.9 mb (60318 kb)
https://www.dropbox.com/s/xk49mq38ch...20CD.part3.rar
Jim Lombardi
Last edited by jimlombardi; 04-18-2013 at 11:31 AM. Reason: Fix weblink to Part3.rar
Jag#4 (03-17-2013)
  #46
Old 03-20-2013, 04:21 PM
xenophobe's Avatar
Ok, I have JTIS running on my Vista x64.
I have a problem, how do I figure out how many hours a particular operation will take?
  #47
Old 03-20-2013, 08:20 PM
You can subscribe to Alldata DIY for $9.95 that gives you repair procedures, part numbers and shop time hours.
Here is the weblink to their website
ALLDATAdiy.com Leading Source of Factory Automotive Repair Information
When the webpage opens:
click on the Select your vehicle now button (brings up the year, make, and model selection page)
then it brings up webpage with the Add to Cart button
then next webpage has the checkout button
then webpage gives a place to enter the Certificate or Discount Code - type in ALLDATACG6 to get special discount pricing for 6 month subscription of $9.95.
Use the 6 month subscription period wisely and try to copy as much info that you can, such as part numbers and labor hours.
Jim Lombardi
  #48
Old 04-18-2013, 11:19 AM
JagTheRipper's Avatar
Hi,
I get "Invalid Link" on the third link. Can you double check it, please?
Cheers,
Kari
Jim Lombardi
  #49
Old 04-18-2013, 11:36 AM
Karl
I fixed the weblink to the dropbox.com for the 3rd archive file in the earlier post# 45.
But here is the corrected weblink:
Jim Lombardi
  #50
Old 04-18-2013, 11:43 AM
That was quick! Thank you sir!
  #51
Old 05-11-2013, 01:06 PM
Sambo21's Avatar
Default Intallation problem
Hi Jim,
I downloaded and installed all files as outlined here, going slowly and carefully, on my Win Pro 64bit. No error messages appeared at any point. Registration of the DAO350.dll file through DOS was successful. Lots of files in the JTIS21 folder. But...
The C:\Jaguar folder was not created so I can't start the program. Is there a way to start it directly from the JTIS folder? Or ...??
I would be most grateful for any help or suggestions.
Sam
  #52
Old 05-11-2013, 05:16 PM
Hi Tony
Sounds like you did not run the setup.exe in the C:\JTIS21 folder.
The setup.exe creates the C:\jaguar folder and the other files in that folder (such as jjtis.exe that runs and opens the JTIS software).
Jim Lombardi
  #53
Old 05-11-2013, 06:37 PM
Sambo21's Avatar
BINGO!! That was it.
Let me add my sincere thanks for all the work you've done to bring this program to us -- and for hanging in there for support. You da man, Jim.
Sam
  #54
Old 05-13-2013, 10:01 AM
2000CAXK8's Avatar
I am having some problems getting this to run well on windows 8 64 bit
All is installed but there are no graphics. I need pictures!
I think it is related to the windows help 32 bit. Will update if I can fix it. (The supplied windows help updater does not run on windows 8)
KellyXK8 (07-16-2013)
  #55
Old 05-13-2013, 12:31 PM
Here is the weblink to Windows Help program (WinHlp32.exe) for Windows 8 Microsoft:
https://www.dropbox.com/s/0wtvz3ux3s...917607-x64.msu
Jim Lombardi
  #56
Old 07-16-2013, 03:07 AM
Pigi's Avatar
Gents,
Is this installation method good for Win7 32bit systems?
  #57
Old 07-16-2013, 03:22 AM
Pigi's Avatar
  #58
Old 07-16-2013, 05:35 PM
KellyXK8's Avatar
Any Idea if it will run on windows 8?... I know I hate it too
  #59
Old 07-16-2013, 05:36 PM
KellyXK8's Avatar
ahhh just read 2000CAXK8s post... i had the same problem
  #60
Old 07-23-2013, 12:44 PM
Update: If you get an invalid link error when you try to run the dropbox PDF weblinks below, then you need to go to post# 62 to fix DNS error on your PC.
End of Update
Here is what you need to know before you download and install the JTIS21 software
First you need to determine whether your PC has a 32 bit or 64 bit Operating System.
Method to determine Windows XP 32 bit or 64 bit
Look at this JPEG (has instructions/illustrations) Click on the image when the dropbox webpage to get a better view:
https://www.dropbox.com/s/0zo00wh83i...20bit%20OS.jpg
Method to determine Windows 7 (32 bit or 64 bit Operating System):
https://www.dropbox.com/s/khcyplnz98...20bit%20OS.jpg
Important step after you download the JTIS21 archive files and after you start the running the 1st archive (exe) file to extract the files in the 3 archives - make sure you put in the C:\JTIS21 as the Destination folder
This PDF covers install on a 64 bit Windows 7 Operating System (also the other windows 64 bit OS - Windows 8, Windows 8.1, XP, and Vista):
https://www.dropbox.com/s/fe6jkw5py3...bit%20v1.6.pdf
If you have windows 8 64 bit you may have to download the microsoft 32 bit help software for windows 8
If you have windows 8.1 64 bit you may have to download the microsoft 32 bit help software for windows 8.1
https://www.dropbox.com/s/fehtnmqpc9...917607-x64.msu
PDF file for JTIS21 install on 32 bit Windows Operating systems (Windows 8, Windows 7, XP, and Vista):
https://www.dropbox.com/s/j6wjvc5esl...%20systems.pdf
https://www.dropbox.com/s/fvdg6rsl63...CD.part1.exe?m
https://www.dropbox.com/s/bwx4uch8m9...CD.part2.rar?m
https://www.dropbox.com/s/xk49mq38ch...CD.part3.rar?m
Decide where to place the JTIS files after they are extracted (CD or on PC hard drive).
This PDF describes both the CD and Hard drive processes:
https://www.dropbox.com/s/dt47u5qcx5...structions.pdf
Jim Lombardi
Last edited by jimlombardi; 02-20-2014 at 01:33 PM. Reason: I added in bold to mark importance of the destination folder
Quick Reply: Details on Win7 64 bit new install method & new JTIS21 XK series archive
