Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Diagnosing worn valve guides or guide seals
LinkBack Thread Tools Search this Thread
Old 03-23-2012, 03:42 PM
OregonJag's Avatar
Question Diagnosing worn valve guides or guide seals
Probably a question for the techs that have had opportunity to work on an AJ-26 with over 150k miles. I'm contemplating a DIY install of new valve seals.
I'm looking at symptoms that normally indicate a lot of oil going by the intake guides:
  • oil consumption is about 800-1000 miles/quart and not leaving any on the ground
  • tell tale pinging when increasing throttle that goes away shortly
  • whisp of oil smoke when increasing throttle that goes away shortly
You guys with engine teardown experience check me on the following:
I'm pretty sure I can get to the valve seals by R&R the cams and using the old string trick to keep the valves up in the guides. I can then check for guide wear and replace the seals. If the guides aren't out of spec I'd put it back together and see if it solved the pinging and oil consumption.
Of course if the guides didn't pass muster, the heads come off and I finish it right. An "opportunity" to inspect the 170k nicasil and the lower chain tensioners.
Any idea if the Lincoln LS valve train has common parts with the old AJ-26?
Thanks for the input,
Mike
__________________
'97 XK8 roaming the Pacific Northwet daily. 192k miles....
.. hey the sun's out . . . . .
Close the umbrellas and open the top! ...
Uh-oh, the rain's coming back ...
Tags
diagnose, guide, guides, guildes, install, noise, pinging, seal, seals, symptoms, train, valeve, valve, worn, xk8, xkr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
