Door microswitch
#61
That's what I did and that's the result I got. What now?
Gus (03-11-2013)
#64
Received 6,250 Likes
#65
Not exactly intuitive to get to or remove! Here's the JTIS procedure:
JTIS - XK8 Drivers Door Module.pdf
You'll have to reset window travel limits after the battery disconnect.
David's XKR (03-21-2013)
#67
Attachment 36042
Attachment 36042
#69
#71
It turned out to be the door module. If I would have tested the original switch before ordering the new one I would have saved a lot of time and effort. Thank you to Steve, Gus, GGG and all the forum members for their time and efforts, without which I probably wouldn't even have bought a Jaguar for fear of maintenance costs.
steveinfrance (03-21-2013)
#72
I think I speak for many here when I say this Forum is the reason we can own a Jaguar.
#73
It sounds like the microswitches in my passenger door latch have a problem, since I am having the window problems and the fact that the car does not recognize that the door is open. I want to try the WD40 fix before operating on the door to remove the latch. Do you just blind shoot WD40 in and around what you can see from the end of the door or is there some particular place to lubricate? Thanks! David
#74
#76
#77
I fixed my door open light by doing the old computer hard reset. I ordered an Omron switch and a lock assembly from ebay. The parts still have not arrived but the problem is gone. I have an xj8, but found a few xk8 threads that helped. Not sure if the reset will fix XK8, but I think both cars are similar in wiring logic.
#78
Not quite sure if this the right thread, but have searched through many. The driver's door window is stuck in the open position. I can hear a feint clicking when trying to close the window. Passenger side window works perfectly as does the soft top on 2005 XK8 convertible. Is it a reset problem or should I remove the door panel and investigate further?
#79
#80
Hello everyone!
I'm new here so please forgive me if this has already been covered, but my 97 XK8 convertible has developed an issue where the driver's window rolls all the way down when the door is opened. The Jag service guy said it needed a door module (LJE2120AB00) which is VIN specific. The car sits a lot so I thought it might be a bad battery core and sure enough, when I put a new battery in a few weeks ago the problem went away and I thought it was resolved. But yesterday I put the finishing touches on the car thinking I finally had it perfect and when I opened the door to get out the window goes down again.
Any insight would be super appreciated!
