Drive Cycle for Green ECM...
I have a P0456 code that I am trying to diagnose. JTIS states that a drive cycle for a green ecm (proceedure detailed in JTIS evap emissions section) should be performed whenever the battery is removed or disconnected and reconnected. I have not done this yet, but does anyone know if this could be causing my P0456 code? I have had to disconnect and reconnect my battery several times recently to do some work. Thanks for your input....
L : P0456. LEAK DETECTED. 20 THOU.
L1 : CHECK FUEL FILLER CAP FITMENT AND CONDITION OF PIPES AND CONNECTORS.
No REPAIR as necessary. CLEAR the DTC. Carry out a full Evaporative system monitor drive cycle, RECHECK DTCs. For additional information, see 'diagnostic drive cycles' above.
- Make sure that the fuel filler cap is correctly installed and tightened. (Minimum 3 clicks).
- Check the condition of all accessible pipes and connectors in the vapor line.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
