Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Easy Fix For P0171, P0174 and/or Cracked Air Duct
LinkBack Thread Tools Search this Thread
Old 01-13-2011, 01:48 PM
Default Easy Fix For P0171, P0174 and/or Cracked Air Duct
I tackled the nagging P0171 and P0174 (lean in bank 1 or bank 2) with a fairly easy fix. I checked this forum and found that one of the usual causes was air leaks between the MAF sensor and throttle body. I checked the air duct on my car and sure enough it had cracks along the bottom in the bellows section. Instead of buying a whole new duct ($$??) I cut out the bellows and installed Nissan part number 16578-CA09A, cost $20. Much better than the original set up. As an added bonus it makes the air filter access easier and lessens the risk of creating a leak after you check it.
The Following User Says Thank You to lostcause For This Useful Post:
teckwing (01-13-2011)
Old 01-13-2011, 05:46 PM
XKRacer's Avatar
/pages/Paragon-Design-UK-Ltd/171022832925953
I have been dying to use that emoticon
__________________
As it happens so often
www.paragondesignuk.com
Old 01-13-2011, 06:37 PM
Don't need no stinkin' picture!The repair is so straightforward you don't need one but for the mechanically challenged here's a mental one: Replace the failed cheap plastic part with a nice new rubber bellows like it should have been made to begin with.
Old 01-13-2011, 07:34 PM
Was this for a XK8 or XKR?
Old 01-14-2011, 12:27 AM
H20boy's Avatar
here's the part....
Click the image to open in full size.
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 01-14-2011, 02:01 AM
XKRacer's Avatar
The last induction pipe I fixed, I made myself, I do that a lot........
There's no way a cheap piece of convoluted hose will get in one of my engine bays
__________________
Old 01-14-2011, 01:50 PM
H20boy's Avatar
xkracer, make me one...from TB to MAFs PM a price!
__________________
My Jag Galleries
Go Texas Tech!
Old 01-15-2011, 12:45 AM
XKRacer's Avatar
No worries Matt I can do that, just let me know if you have a breather coming out of the induction pipe at the TB end? Or post up a pic, there is also a slight chance the US spec ones might be slightly different but dimensionally they will all be the same.
__________________
Old 01-15-2011, 11:16 AM
MarcB's Avatar
I am very interested in that set up as well. My XKR has the breather where the induction tube enters the TB - it is 90 degrees to the TB opening. Do you also have it routed into the fender well for cold air?
Please excuse the dust, ran through a little dust storm here.
Easy Fix For P0171, P0174 and/or Cracked Air Duct-intake-001.jpg
Easy Fix For P0171, P0174 and/or Cracked Air Duct-intake-002.jpg
As far as I have been able to tell the induction pipe is the same for both Euro and US XKs (Rs and 8s are different I was going to put an XK8 pipe on to eliminate all those parasitic sound control tubes but your set up is so much better)
__________________
2006 XKR Victory Edition/4.2S Convertible
120k miles. Quartz/Dove - Mina Gallery exhaust, custom "X" pipe, Mina lowering springs, Powerflex control arm bushings
2006 Super V8 Portfolio
80k miles. Black Cherry/Conker
IDS lowered, poly control arm bushings (comfort) and ACM
Previous Jaguars:
1999 XK8 Convertible - Sapphire/Ivory
2001 XJR - Sapphire/Oatmeal
2006 X-type Sportwagon (Estate) Wintergold/Champagne
Old 01-15-2011, 02:56 PM
Goldlion's Avatar
XKRacer
Very sharp looking setup. I would also like one for a 2005 XKR Coupe. Please email the cost and I will get back with you.
Tim V.
Old 01-15-2011, 06:00 PM
XKRacer's Avatar
Not a problem I can make a few up.
Looking at Marcs, I reckon he could do with some strut caps and aluminium strut braces as well
__________________
Old 01-15-2011, 06:19 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
Send a message via Skype™ to Gus
I think I Like this idea.
__________________
Gus
www.jagrepair.com
XK8 1999 130,000mi K&N Filter, S-Type 2000 3.0 120,000mi K&N Filter
“If you can't dazzle them with brilliance, baffle them with bullshit.”― W.C. Fields
Insanity: doing the same thing over and over again and expecting different results.-Albert Einstein
“I fear the day that technology will surpass our human interaction. The world will have a generation of IDIOTS.” – Albert Einstein
Old 01-16-2011, 01:08 AM
H20boy's Avatar
No goofy baffles on mine, and ive got the same breather stub as marc. Crappy pic attached from my phone. Strt brace? I didnt think that was possible?
__________________
My Jag Galleries
Go Texas Tech!
Old 01-16-2011, 07:08 AM
MarcB's Avatar
You are correct, strut caps would be an excellent addition and as Matt mentioned - Strut brace? Tell us more!!!
__________________
Previous Jaguars:
Old 01-16-2011, 08:54 AM
XKRacer's Avatar
OK Strut brace might of given you the idea of the, across the engine bay connecting the 2 together.......And your are right, it is impossible, there simply is not the room under the hood.
What I have done is recreate the OE steel tube items you see fitted to convertibles, going from the strut to the bulkhead. These are made from solid aluminium (7/8 dia) and fit to the strut via a stainless ball joint.
I do have pics of some fitted to my coupe, quite a few people do not realise the holes the convertibles have to fit the brace to the bulkhead are also present on coupes so can be fitted.
When I am back at work on Monday I will take a pic
__________________
Old 01-16-2011, 01:13 PM
H20boy's Avatar
I think I see what you mean, the brace at the strut tower back to the firewall...at about a 45-deg angle. correcto?
__________________
My Jag Galleries
Go Texas Tech!
Old 01-16-2011, 01:25 PM
XKRacer's Avatar
Correct
__________________
Old 01-16-2011, 08:17 PM
I would like to know what your breather tube costs also. And the wire mesh louver inserts for XKR hood, like MarcB's. What else to you make?
And, I had wondered to myself whether there were threaded holes on the coupe for mounting the convertible struts/supports as I thought it could only help...thanks for answering that too.
__________________
2000XKR Platinum Coupe, 65 S-Type, 62 Vette, 55 Chevy, Kawasaki Nomad
Old 01-17-2011, 05:50 AM
XKRacer's Avatar
I will work a price out for you guys, it will be a little more expensive for those with the newer XKs because of the extra breather, just give me a couple of days.
I have a 2004 XKR with the later type so I can do a drawing and produce a few.
Below is a pic of the strut cap and brace, in this pic the brace still needs polishing but you can see how it fits onto the strut tower
@ Steve, you need to have a wander around my website www.paragondesignuk.com basically I can do anything (well amost anything), there is still alot I have not put up yet, it is as with life, a work in progress!
__________________
The Following User Says Thank You to XKRacer For This Useful Post:
deuce2000 (12-21-2012)
Old 01-17-2011, 09:30 AM
H20boy's Avatar
Xkracer is a fabricating genious...if it can be made, he'll do it. If he hasn't thought of it yet, I bet he can build it. I'm surprised nobody has asked for those snazzy 'halo' lights.
__________________
My Jag Galleries
Go Texas Tech!
Tags
171, 1999, 2004, 2006, jaguar, p0171, p0174, po, po171, po174, rav4, toyota, type, xj8, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
