engine knocking on startup cold
Old 01-04-2012, 05:02 PM
LedZepplin's Avatar
Default engine knocking on startup cold
I have a 2001 XKR 53K miles. When I start my engine from cold i.e. after 24hrs rest I hear a loud knocking noise coming from the center/top engine about where the super charger is. It goes away after about 20sec and is never heard from again until another cold start. I'm 90% sure its in the middle and not the cam cover area and yes I have changed the secondary tensioners.
Any ideas ??
Simon
Old 01-07-2012, 03:02 AM
GGG is online now
Received 16,767 Likes on 12,155 Posts
Simon,
You're not going to get many replies unless you link an audio of the noise. (rattles from chains, rumbles from camshafts, slap from pistons, clicking from valves etc etc - the list of possibilities goes on and on)
From the information you've given, this loud knocking noise happens:
1. only when the engine is cold
2. it stops in about 20 seconds
All clearances are therefore at maximum and all the oil has drained back into the oilpan. This suggest something worn where the clearance is great enough to be noisy at startup but not so worn as to continue when oil pressure is up to normal. Stopping after 20 seconds is too soon for engine warm up so this is likely to rule out expansion in anything other than an exhaust component.
Have you had someone start the car whilst you listen standing next to the engine? You need to pinpoint the sound. Definitely from the engine itself or an ancilliary? Top end or block? Removing the engine covers will make it easier to locate.
Is it as simple as using too lightweight an oil or a filter without a non return valve?
Get recording - there can't be many Jaguar noises someone here hasn't heard before.
woodlandsPRO (05-10-2023)
Old 01-08-2012, 01:49 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
What's the status of your tensioners Simon?
Is it only the supercharger, or in the engine? I hear lubrication of that supercharger makes them pretty noisy.
Old 01-10-2012, 01:09 PM
LedZepplin's Avatar
I had the rocker covers of at the weekend to re seat them, the drivers side was weeping a little oil in the bottom right corner. Tensioners are fine those I replaced 4K ago with the metal bodied ones and they looked good.
The noise seems to be coming from the supercharger which is strange as I dont think that is oiled from the engine seems to be sealed for life LOL. Wonder if it needs its oil changing. If so does anyone have clear instructions for this.
Noise only lasts a few seconds so it may just be the cold, I'm in CA so cold for us is below 50F, my supercharger belt always squeeks like a mouse when the engine is cold but this is a known problem goes away soon as the engine warms up. My car has only ever lived in FL and CA so it does not like cold weather. Think its seen rain like twice in the last 7yrs LOL. Only dirt my engine top/bottom has is dust!!
Thank
Simon
Old 01-12-2012, 07:26 AM
oldmots's Avatar
The supercharger has an oil bath lube with a level check plug for the front bearing and a sealed lubricated rear bearing. The life of the unit is about 100K so you are not there yet. The only thing I can think of that could knock there is the internal snout coupling on the supercharger. This part can fail and cause noise so get it looked at.
Old 01-12-2012, 07:44 AM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Thank
Simon
Here is a link fyi to a supercharger oil change write-up, but I doubt it is the solution to your problem. https://www.jaguarforums.com/forum/x...ge-pics-60260/
Old 01-12-2012, 01:35 PM
H20boy's Avatar
above thread links to another thread too
https://www.jaguarforums.com/forum/x...e-notes-57136/
Old 01-13-2012, 06:53 PM
LedZepplin's Avatar
thanks I've order the oil for the super charger so will change that as it has not been done since the car was new i.e 53K ago!!
Old 01-13-2012, 07:09 PM
H20boy's Avatar
hey, it won't hurt anything for you to do so. It may still rattle, but she'll be cooler when making all that racket.
Old 01-16-2012, 05:33 PM
LedZepplin's Avatar
Ok changed the super charger fluid well sort of. I could only get about 1oz out and I tried every angle with my WD40 pipe but it did take 4oz to fill it back up. So there was 3oz missing. Guess a seal is leaking a little as there was oil and grime about the SC.
Engine does sound a lot quieter now when running and start up still a little noise but nothing excessive for 53K miles.
Old 01-16-2012, 11:26 PM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
You should watch your lube level then.
If you were down 3 ounces, that is roughly half of the 6.8 ounce capacity.
Old 01-17-2012, 12:05 AM
avt007's Avatar
Listen to these videos and see if they are the same as your sound.
https://www.jaguarforums.com/forum/x...d-video-61236/
Old 01-17-2012, 07:08 AM
itspec60's Avatar
My engine starting doing the same thing right after an oil change. I had changed my tensioners 5000 mi. before and everything was fine until the change. I then started checking the differences in oil filters. I had used one that did not have an anti-return valve. I bought one that advertised it had the valve and changed filters. I haven't had that noise since.
Old 01-17-2012, 11:05 AM
LedZepplin's Avatar
Not really that sounds like VVT tappet sounds. Today is really cold we had first frost of the year so I will record it this afternoon and post.
http://www.youtube.com/watch?v=tYCqfh-wifk
The sight tick you hear when the revs drop is the supercharger belt. Didnt knock much this morning and has been sitting for 16hrs overnight in subzero temps. Think this car just makes you paranoid!!
Old 01-18-2012, 01:39 AM
H20boy's Avatar
doesn't sound noisy at all. Mine taps a bit too...but that little chirp would drive me batty.
Old 01-18-2012, 09:54 AM
XJR-99's Avatar
I have exactly the same knocking noise 30-40s after cold starts when parked one day or more. 1999 XJR. I have tried to hear from where it comes, sounds like from timing chain area, but not 100% sure. Old tensioners ( will be changed soon ) and SC oil changed 5K miles ago. The noise is quite a strong knocking one, not very fast, maybe once per every 1-2s.
Old 01-18-2012, 10:49 AM
LedZepplin's Avatar
The chirp is there some day other not and goes away once the car warms up. You cant hear it when you are in the car with the door closed. Its just the SC belt slipping. Happens after the car is left for a day or so, the belt slips on the small SC pulley. If you give the belt a good clean with soapy water that helps.
But as I said 50% of the time is not there and it always goes once the engine warms up.
Old 02-09-2012, 05:13 PM
guzzi svt's Avatar
I just had all of my cam chains and tensioners replaced and was hoping that would get rid of my knocking at cold start too, it did get rid of the tick, tick, tick that had started last time I drove it. The knocking started about 5 years ago soon after I bought it.
I finally had a chance to listen to it, it wasn't easy because it only makes the noise right after you start the cold engine and then really only when you put it in reverse. It make the noise at idle but putting it in reverse really sets it off. My brother was over so he listened while I started it and put it in gear. He said it's coming from the SC. We switched places and he was right. It started to quite down after about a minuite of running. I'll be checking and changing the oil soon, but am interested in anyones idea why it would be making this noise. Gears banging together w/o oil?
Old 09-08-2012, 04:02 PM
PascalR's Avatar
Hello all,
I am just registred in your forum, I am living France and I read your posts since a while because I have the same symptoms ( knocks at cold iddle )
'98 engine, Tensionners are new, engine oil new, supercharger oil new, 89000 miles at clock, the car is running fine but, there is still this knock when cold start.(the same as the video of the red XKR, i cant find it !)
I located it also under the supercharger, especially on passenger side, and the noise resonate in the intercooler.
I saw some XKR owner having this matter, it let me think it's a common problem on these engines but nobody has sorted it out (even me....)
I use now 95 unleaded gazoline instead of 98, the noise is not that present.... this could be a way.
Many thanks for your suggestions.
Old 09-09-2012, 05:44 AM
XJR-99's Avatar
Knocking noise of my car's engine just after cold start ended when full timing chain job was done. Most probably the noise really came from this part of engine.
Quick Reply: engine knocking on startup cold
