engine knocking on startup cold
Old 09-10-2012, 02:43 PM
guzzi svt's Avatar
I notice something new about my knock this weekend while at a big Ferrari get together in Eureka Springs Arkansas. I was more than a little embarrassed as I started my car and slowly drove it through the parking lot to the hotels front canopy were I parked and turned the car off while I went inside to discuss my bill with the manager. After returning in about 10 minutes and restarting the car in the presents of a nice Corvette owner, to my surprise, and relief, the noise was gone.
I think the short one minute drive and then 10 minute wait time must have heated up whatever parts are knocking. So my conclusion is heat, and not a lot of it, is required to quiet things down. This also remove oil pressure as a culprit.
The lower octane relief is interesting as it does sound like a diesel engine, but lowering the octane? The knock is also cam speed. It’s at the same tempo as the injectors which means it only makes its noise only during combustion. I have asked the jag dealer to kill one spark plug at a time when we try to find it next time I take it in, I’m not sure if they really want to see it again anyway. Is there any way of doing this through the ECU?
How about wrist pin or small end rod knock. I know the piston does reshape itself as it warms up. That's why a piston has Cam Grind ( being oval) of 1 or 2 thousands.
Also here in the USA we only have 85,87 and 91 (sometime 92 or 93) I'm not sure how they measure it in France but it may be similar octane to ours.
Old 09-10-2012, 03:41 PM
PascalR's Avatar
I think it is the same way every where...
This car (mine, 1998) is made to run with 95 here in europe. It is mentionned in my owner's book if I remember well.
Old 09-12-2012, 11:56 AM
guzzi svt's Avatar
In the USA we use a average of MON and RON ratings to come up the with octane rating, I think the world just uses RON.
Please correct me if I'm wrong.
Old 09-12-2012, 02:44 PM
PascalR's Avatar
In europe we use RON. but I am not familar with ...
Old 03-22-2022, 01:45 AM
Robin Harriram's Avatar
Default Rob
Originally Posted by H20boy
What's the status of your tensioners Simon?
Is it only the supercharger, or in the engine? I hear lubrication of that supercharger makes them pretty noisy.
I have 2004 4.2 v8, which rattles, like loose tappets on cold start only.for about 3 seconds. quite loud Rest of time no rattle. My guess is that all the oil seeps to the sump and its a dry start, in the heads.
Old 03-22-2022, 02:36 AM
Pistnbroke's Avatar
Piston slap. If you have the old dipstick raise the oil level 1 quart (about 1cm) as in the Jag advisory.
Sparkers69
04-19-2024 07:16 PM
Louenigma
21
06-13-2016 06:38 PM
trosty
03-05-2015 11:38 AM
Bigvettefreak
10-01-2012 11:37 PM
coastaljag98
09-23-2012 08:09 PM
Quick Reply: engine knocking on startup cold
