Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Front Crank seal and engine mount replacement, OMG!
LinkBack Thread Tools Search this Thread
Old 04-04-2013, 01:24 PM
Default Front Crank seal and engine mount replacement, OMG!
It finally happened, I am replacing front seal and left mount, after that.
What a SOB job that is, I tell you.
Front pulley is sitting on a cone shaped shim insert, which keeps pulley tightly on, even after it is broken off its place. Not too mention that front engine wall is made of eggshell thin aluminum, so any kind of prying will break it.
Seal itself is some odd plastic seal, with no round spring at all, just waiting to harden up and leak. There is also an o-ring inside the pulley, preventing oil leaks from the center bolt, that ring fossilized into pure plastic.
Front Crank seal and engine mount replacement, OMG!-dsc01249.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01250.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01251.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01253.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01254.jpg
__________________
'62 Mark2
'82 XJS HE - 5 Speed V12
The Following 2 Users Say Thank You to Mish_Mish For This Useful Post:
plums (04-04-2013), WhiteXKR (04-06-2013)
Old 04-04-2013, 01:31 PM
The Coupe's Avatar
Yes, please DO post some photos.
Did you develop a big oil leak up front? Did the seal die slowly or all at once?
__________________
1997 Jaguar XK8 Coupe, Sherwood Green / Coffee
- According to Jaguar Heritage, my car was assembled on 13 May 1996, in a pre-volume build group of 111 cars for management evaluation and photography.
- This group of "4P" cars featured all options and represented all international markets. The first true customer XK8 was produced 23 days later.
- The engine was assembled on 15 March 1996, in the first two weeks of AJ26 4.0 engine production.
- 125,000 miles, modified and growling nicely!
Old 04-04-2013, 01:38 PM
It kept PMSing on my garage floor, for a while, but small drops kept developing into puddles, until I was adding 1 qt of oil per ~500 miles.
It was definitely that damn seal, because I could see radial oil streaks going from the crankshaft.
__________________
'62 Mark2
The Following User Says Thank You to Mish_Mish For This Useful Post:
The Coupe (04-04-2013)
Old 04-06-2013, 08:14 AM
Ok, talking to myself here, but still need to update all ya'll.
Job is done and here is thee sequence. To get left mount replaced, best way to do is pull the steering rack off its place and disconnect steering shaft. Very important to make a tiny mark on the shaft with metal punch, to know how it goes back together. Otherwise steering wheel is gonna go off center.
Entire process is done from underneath, so do not bother squeezing between manifold and side wall.
Also, be very careful unbolting X-brace off the bottom of front end. Front bolts are rusting onto thread in core support, so brake fluid has to be applied inside core support, where these bolts are. I managed to break one off inside and ended up welding stud onto core support instead.
Front seal is made of plastic and has no internal spring, kinda odd style, but I bought original one anyways. There is also thin o-ring to be replaced, it goes inside front pulley, it secures oil from coming out from the center bolt.
Front Crank seal and engine mount replacement, OMG!-dsc01267.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01268.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01269.jpg   Front Crank seal and engine mount replacement, OMG!-1.jpg   Front Crank seal and engine mount replacement, OMG!-dsc01271.jpg
__________________
'62 Mark2
The Coupe (07-03-2013)
Old 04-06-2013, 09:48 AM
dsnyder586's Avatar
FYI- I was able to do it with a hoist- lifted the engine just enough to wiggle it out after removing the nut on the other side as well.
__________________
[OCJAGUARCLUB]dsnyder586
Old 04-06-2013, 12:46 PM
Quote:
I could not get hoist above lift, so we decided to go from the bottom.
BTW, is it true that right mount is usually OK, or do I need to replace both?
__________________
'62 Mark2
Old 04-06-2013, 06:45 PM
Do NOT lubricate the seal lip when you install the front pulley. They are designed to be dry, unlike a standard seal. You can likely press it into place with your fingers, but be careful not to allow it to pass all the way through! There is no lip inside to stop it! As for the mounts... yep, not much fun.
Old 04-06-2013, 08:11 PM
Quote:
I did not lube it much, just gave it a rub around with my greasy fingers.
Pressing it in was not hard and I did realize that it would fall in if went too far.
Important part is tiny o-ring inside the pulley, because this is what prevents oil from coming out of pulley bolt. Thanks!
__________________
'62 Mark2
Tags
broken, conversion, crank, crankshaft, engine, front, leaking, lip, mount, part, powered, replacement, seal, vbulletin, xk120
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
