Battery Replacement Recommendation - UK
Normally, I just go with the lowest cost for the highest power. However, I thought I was lucky to actually find a repacement battery for Kitty at Walmart. It's specifications exceeded the OEM's and it cost less than an alimony check () . It's been in the car for two years and 40,000 miles - no problems.
I got a Varta H3 100Ah recently from
www.battery4cars.co.uk
Battery is : VARTA Car Batteries by a leading UK Car Battery online supplier.
for £82.00 + delivery at £9.99 = total £91.99 which seemed like a very good deal.
Arrived quickly - well packed - included vent elbow - can recommend.
Cheers,
David.
Cheers,
David.
JimC64 (09-11-2014)
Can i use an Optimate 4 charger
to charge my 1998 XK8 ?Optimate 4 Battery Charger - Demon Tweeks
I'm going to buy a new battery soon - is these a specific name or number for the properly vented battery - looks like the previous owner bought quite a cheap one.
Thanks for the help guys.
ok the battery i have in it now is a: Lion Battery looks like it's 88Ah
My guess is this is a general one and not the best for the car.
The full ref nos for it seems to be 017 88Ah EN 680cca
Lion 017 Car Battery 88Ah 680CCA 3 Year Warranty
any thoughts? Thanks.
To quote a post I made on another Jaguar Forum!
The OE battery for your XK8 is a VARTA made in Germany. Part Number C2D22312. Specification is 90Ah and 800 amp. Cost from Jaguar last month was £95.79 (less any discount your dealer may give) plus VAT.
Just Google [Jaguar + XK8 + Varta + battery] and it will return several UK suppliers.
LondonXK8Boy (09-12-2014)
Brilliant - thanks Graham that's the one for me - hope u don't mind a dumb question - will that come ready to fit - no charging up or anything?
I've been looking at the this link for reconnection:
https://www.jaguarforums.com/forum/x...ect-faq-74146/
They always come from a Jaguar Dealer charged and ready to fit. If you source from elsewhere, check before you buy. The adaptor for the vent is usually packed separately. There's a blanking plug to remove and the right angled vent adapter is then a push fit.
Things to consider with battery disconnection are:
1. radio code required (for UK vehicles)
2. reset window limit switches
3. fuel trim adaptations will automatically reset to default values but will 'relearn' as you drive
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
