fuel gauge issue
Old 03-11-2012, 11:18 AM
skubeedoo's Avatar
Default Same Issue
My fuel gauge is also not correct. Full is about 3/4 and empty, don't know, but I'm guessing around 1/4. OregonJag mentioned: a loose connection to the instrument cluster. I feel this might be true with my issue because it will remain like this for a month or two, then the gauge will "readjust" to a new position and remain there for awhile.
Where can I find the "connection to the instrument cluster?"
Old 11-19-2012, 09:26 PM
yyk's Avatar
yyk
yyk is offline
Default Fuel gauge Sender issue
I just saw on Motor Week last week that high sulpher in gas can cause the silver in the variable resitance unit to corrode and before attempting a mechanical fix you can try a BG gas additive to remove the corrosion in the sending unit silver to correct the problem. Not sure which additive but the can is gold colored with white letters.
Mike
'00 XKR Coupe
Old 03-13-2018, 01:00 PM
mikegs50's Avatar
Default fuel gauge
01 XK8
My fuel gauge has not worked for two years.
The car developed a slight stumble and I was advised to add JB 208 to my fuel. Now the stumble is gone and my fuel gauge has come back to life. NOW I will use JB products on a regular basis.
Old 03-13-2018, 03:37 PM
Jon89's Avatar
Received 4,275 Likes on 2,812 Posts
Hmmm, I wonder if the JB 208 fuel additive product actually resolved your fuel gauge issue. Perhaps hitting a nasty pothole or bump jarred your fuel gauge float out of its stuck position. No way to really know, I suppose....
toronadomike
08-07-2022 03:41 PM
99xk8guy
09-21-2019 07:34 PM
giandanielxk8
09-06-2015 07:21 PM
AL NZ
09-04-2015 08:39 PM
Bcrary3
09-03-2015 03:48 PM
Quick Reply: fuel gauge issue
