Fuel Injector cleaner
Old 11-01-2013, 03:56 PM
n17gary's Avatar
Default Fuel Injector cleaner
I was advised to use some Chevron Textron cleaner to increase my mpg. Any experience with this cleaner? I have never used an injector cleaner in this car. My XKR is a 2001 with 74K miles. Car runs good with ave mpg of ~19.
Gary
Old 11-01-2013, 05:20 PM
TreVoRTasmin's Avatar
I run it thru all my cars once or twice a year when it is on sale. Does it do anything? Couldn't answer that one but I've never had a sticky injector nor have ever replaced an injector.
n17gary (11-09-2013)
Old 11-01-2013, 05:24 PM
Received 2,255 Likes on 1,840 Posts
I've never used any injector cleaners and never had a faulty injector or any other problem. Today's gasoline has more than enough additives already in it.
Old 11-01-2013, 08:32 PM
aode06's Avatar
No need to use them, the cleaning detergents are already in the gas.This is why gas burns so fast, its not pure.
Have the fuel filter changed.
Old 11-04-2013, 08:12 AM
CoventryCars's Avatar
+1 on changing the fuel filter! I just changed mine and the amount of sediment that came out of the old one was eye-opening.
The following 2 users liked this post by CoventryCars:
Bob OB (11-09-2013), n17gary (11-09-2013)
Old 11-04-2013, 04:39 PM
mike66's Avatar
I've heard the Techron advice for along time, but it's true, all gas, esp. the name brands, have additives to clean. Techron is Chevron's, and has a good reputation, so if there's a station nearby, go for it. Probably the best advice I read was to switch up brands from time to time; Shell, Mobil, Chevron, etc. have their own cleaners and what one may miss the other may get. Unless you live in a place where gas turnover at the station is slow it should be a non-issue. Don't we have enough to worry about?
The following 2 users liked this post by mike66:
Old 11-09-2013, 12:24 PM
Mike Graham's Avatar
Seafoam. My mechanic keeps it by multiple cases and says that it has cured many problems and saved his customers lots of money. I have used it and everytime I get rough idling or any kind of hick-up it seems to fix them.
Old 11-22-2013, 01:50 AM
Fyrplg's Avatar
I have used it in many cars. Generally it seems to make them run smoother.
About cost, If you have a Costco outlet near you you can buy a six pack for about the cost of 2 in auto parts stores.
Good luck.
knightofgold
02-11-2016 06:03 PM
ogorir
01-18-2016 10:09 PM
Bigvettefreak
09-29-2015 04:13 PM
ratgawd
09-16-2015 04:15 PM
Bcrary3
09-11-2015 10:36 AM
Quick Reply: Fuel Injector cleaner
