97 Xk8 TB swap
Old 11-18-2010, 11:21 AM
brgjag's Avatar
Default 97 Xk8 TB swap
The TB on my 97 appears to be dead. Is the process of taking it of and putting a rebuilt in it's place hard? It look like tight back there but any special tools needed?
Old 11-18-2010, 07:17 PM
brgjag's Avatar
Anyone?
Old 11-18-2010, 07:50 PM
H20boy's Avatar
Received 1,143 Likes on 749 Posts
sorry, didn't take mine off before...bump for someone who has
Old 11-18-2010, 10:16 PM
XKRacer's Avatar
No special tools needed 45 minute job, the trickiest bit is getting the water pipe off
Old 11-19-2010, 12:56 PM
OregonJag's Avatar
It's easy enough to remove that I pull it off just to make room to work on the hoses back there. Ditto on the water pipe but you can nurse it off, be patient.
Mike
Old 11-28-2010, 06:49 PM
brgjag's Avatar
where is the water pipe? Which side? Special tools needed or will my typical stuff to work on cars work? I am thinking about starting to pull it to have it replaced. If that does not do it then the computer goes out for repair.
Old 11-29-2010, 01:42 AM
XKRacer's Avatar
As you are looking at the car it is on the right hand side but it connects to the block on the left via a steel pipe coming from just above your starter motor, you might find it easier to disconnect from there.
willtoliv
10-02-2015 12:18 PM
speacock
09-25-2015 02:58 AM
Jagged-X
09-24-2015 05:08 PM
Lawrence
XJ40 ( XJ81 )
09-18-2015 02:03 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: 97 Xk8 TB swap
