High Pitch Whine in Engine Compartment... any ideas?
Old 09-17-2011, 02:16 AM
xenophobe's Avatar
Default High Pitch Whine in Engine Compartment... any ideas?
First off, I am not a mechanic.
There is a new high pitch whine, similar in sound to my Chevy Suburban's fuel pump. It's coming from the engine compartment, from the best I can tell, it's behind the supercharger around where the distributor should be.
The whine is pretty much constant. It does change pitch going from park to drive, but revving the engine or driving it does not really change the noise as far as I can tell.
It's going to the shop on monday anyways, but any ideas of what it is?
Old 09-17-2011, 08:04 PM
xenophobe's Avatar
Wow, not a single response :\
Old 09-17-2011, 10:48 PM
Reverend Sam's Avatar
Received 1,259 Likes on 564 Posts
It sounds like my ex-wife might be in your engine compartment.
Old 09-18-2011, 12:56 AM
avos's Avatar
Received 1,062 Likes on 759 Posts
It could be a couple of things, but I can't see the point of guessing to be honest, especially not when you bring your car, as for a good technician it is easy to spot. A recording would have helped though.
Old 09-18-2011, 03:08 AM
Frog's Avatar
Old 09-18-2011, 10:23 AM
Jochem00's Avatar
There is no distributor.
Anyway, the whining noise comes from your acc. Belt.
Easy to replace
Old 09-18-2011, 05:03 PM
xenophobe's Avatar
Easy to replace
Sorry, was having a bad day...
Old 09-18-2011, 07:15 PM
80sRule's Avatar
It may be the throttle body. They make some noise even when the key is just in the on position. Try the key to on, with the engine off and see if that's the noise you're talking about.
Old 09-19-2011, 01:27 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
Agree with 80sRule (which they do BTW, totally). Then again, it could be the climate control. Either way, its normal, and should not be of any concern. If you hear crazy ticking from your driver fenderwell, then I CAN tell you what that is.
Old 09-19-2011, 02:50 PM
malbec's Avatar
Well if it wasn't Rev SAMs ex then it could be this
BBC News - Cat travels 17 miles under car bonnet into Aberdeen
Quite appropriate for a Jaguar
Old 09-28-2011, 11:20 PM
xenophobe's Avatar
Problem solved... it was this thing:
It was the first time my indie shop had ever seen this go bad, and Jaguar no longer stocks this part so I had to get a used one:
Old 09-29-2011, 06:29 AM
What is it?
Old 09-29-2011, 07:17 AM
XKRacer's Avatar
Its a supercharger bypass actuator
Old 09-29-2011, 09:59 AM
Mountaincat's Avatar
What in the heck does it do? Wow Jag. doesn't carry this part for a 2005 MY---hard to believe! Maybe it's special order?
Old 09-21-2015, 02:41 AM
pk4144's Avatar
XENOPHOBE, I am very late to this post but I am having the exact same problem! Just bought a 2011 XKR converible. What exactly was the fix??
Old 09-21-2015, 04:09 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Sounds like it's the solenoid-activated flap that's open except when on boost. Wreckers should have one.
BrentGardner
26
04-17-2024 05:19 PM
toronadomike
08-07-2022 03:41 PM
Russ Graber
02-23-2019 11:59 AM
TC Johnson
09-02-2015 09:30 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: High Pitch Whine in Engine Compartment... any ideas?
