How to get a new key?
My car only came with 1 'normal' key and the valet key. I would like to have a second normal key cut, but how do I find the part number? There are no references whatsoever on my existing key.
There are plenty of uncut keys on eBay, but how do I know which one to get?
Also, how can I get it cut and/or programmed?
TIA
An example of one for sale on UK eBay:
TIA
The blank is the only cheap part of the process. The last XK8 key I got from Jaguar was delivered overnight from Browns Lane to my local dealer already pre-cut.
Because there's a transponder chip in the key head, it has to be paired with the car on the Jaguar dealer equipment. Unfortunately keys are not like the fobs which you can program yourself.
Looks like a trip to Jaguar Lille or Paris.
Frog (02-29-2012)
Found the invoice for this - it was £40 for the pre-cut key and a further £50 to 'tune in' to the car.
The only difference between a black headed key and a green headed valet key is at the very end where it tapers to a 'V'. There's a collar machined around this section of the black key which is missing from the green one. A locksmith could therefore convert your green key to the same profile as the black one and it would then work like the black one and unlock the luggage compartment.
I literally JUST got home from getting a set of keys made for mine at the dealer this afternoon. On the work ticket, the valet key (2004 XK8) is C2N1967, and the regular key is C2N1966.
I was charged a mint for them, cutting, and programming. But, I have full spare set now! MC
From examples I read on the forum, spares costs seem very high in the US compared with UK. The £90 I paid for one black key is equivalent to $143. Mind telling us what you had to pay for your keys?
Be glad to-- but almost embarrassing.
I was quoted $169 per key blank and $130 per for cutting and programming.
I complained because of the particular history of this car. The PO bought it there, had it religiously serviced there, and traded it in there. But, strangely, the keys disappeared between the trade in and the wholesaler. Makes me suspect they get thrown in the garbage so the next customer has to pay for a new set. Just saying (my observation).
Anyway, they gave me the blanks for $125 each, and waived one programming and cutting fee. It was $404.70 out the door for a pair....
MC
MC
CA Jag (07-21-2022)
Y'all are kidding, right?? Wow!
Cheaper if you don't care if there's a kitty on the key head: Jaguar TBE1T5 '97-'99 Master Cloning Key
or
Code reading "Tibbe" keys for Jaguar
How to decode Jag/tibbe key:
Even if the dealer charges you $100 to program (call your local locksmiths, they can probably help you or tell you of someone that will) you'll still be money ahead.
If you absolutely have to have a growler on your key:
Jaguar Factory Master Chip Key - 8 Cut (Factory Original)
or
plums (03-02-2012)
Beav--
I actually did some legwork on this before I dropped 4 large for a set of keys.
Now that I have the part #'s, you could buy the blanks wholesale for about $75 each. I also found a local locksmith that "could" do the programming. But, the problem is getting the keys cut. It seems the later years have "harder" key blanks and it seems "dealer only" to get them cut. I did the "one stop shopping" option, and made an appointment yesterday. Even so, it took about 2 hours. Just glad to have this dark chapter behind me.
Mark
Mark
Update! I had to have a bunch of fobs cut and programmed for my Chyrsler 300. I found a small independant locksmith Ninja. I talked to him about the Jag keys. He says he can do them, and has done them in the past-- gets one request about every 6 months. He said he can do them with generic blanks for $95 a copy. So, it is possible if you can find the right person.
PigletJohn (07-10-2013)
I paid like $20 NZD (maybe 15 US) each for 3 blank keys from a guy in Australia, I don't think they have a chip in them either so I needed to buy chips the off ebay (only a couple of dollars each) and a fob. There is another forum posting about this here search for
DIY Flip Key Conversion without Reprogramming - Guide with pictures.
Sorry I just copied the title and it's huge lol
Received 1,575 Likes
To those trying to make do with only one key;
don’t do it . Getting a dealer sourced key is expensive alright, but losing a key and having to deal with a tow-in and all the inconveniences is going to be even more expensive in both time and money.
It does pay to call around and compare dealer prices. They are going to vary widely.
Z
Z
You go to Sainsburys in UK and they have the blanks..or on ebay for $12 .have a couple cut then put the original key with its chip behind the plastic ignition lock surround and off you go . Or just tape the chip near the lock inside the housing. EPLS ....well your choice.
razorboy (07-20-2022)
Having had only 1 key the entire time I have owned my car, I was getting worried about the possibility of losing it.
More worried about that than the worry of someone stealing the car.
By mounting the original key somewhere close to the ignition barrel, I should be able to just have the keys cut, and the chip will always be engaged
libbysa (05-11-2023)
