How to Remove XKR Steering wheel?
Old 01-07-2012, 08:41 AM
Jag13cat's Avatar
Default Steering Wheel Removal
koolfel98;
Fully extend steering wheel
Rotate steering wheel to 12 and 6 o'clock position
Key in steering wheel - to keep from locking steering
Disconnect battery - wait 30 minutes to discharge memory
Back of wheel, inset screw in back of plastic housing - remove
Move steering wheel to opposite position (180 degrees)
Remove other inset screw
Air bag will come away from steering wheel; electical wiring is still attached to air bag as with all other steering wheel control components (audio, cruise, etc.) which need to be disconnected.
Should be able to see steering wheel nut and remove.
The following 2 users liked this post by Jag13cat:
cjd777 (10-14-2014), The Coupe (01-07-2012)
Old 01-07-2012, 11:46 AM
Beav's Avatar
And always set the air bag/horn pad face UP. If for some reason it was to deploy you don't want it launching itself across the neighborhood!
Old 10-14-2014, 09:44 AM
Gibso's Avatar
Default Gibso
Thanks. Could not work it out.
Old 10-14-2014, 10:27 AM
Dr. D's Avatar
Originally Posted by Jag13cat
koolfel98;
Having broken the two airbag connectors by trying to disassemble them (then having to repair them), I then realized that they are both right angle connectors that simply unfasten by pinching the sides with fingers or long nose pliers. I just did not want anyone else to make the boo-boo that I made.
cjd777 (10-14-2014)
Old 10-14-2014, 11:11 AM
Stamford's Avatar
Ever seen the Youtube videos of idiots putting airbags under seat cushions and firing them? So many ways to kill or injure yourself!
toronadomike
08-07-2022 03:41 PM
prettydaim
03-28-2021 07:47 AM
PMKimpton
08-03-2019 08:22 PM
Beardy
09-18-2015 10:00 AM
sogood
09-15-2015 07:35 AM
Quick Reply: How to Remove XKR Steering wheel?
