how to top up your diff oil
OK, my pinion seal is leaking and I need to keep the diff topped up till I can get the car booked in to change the oil seal in two weeks.
Sounds simple, started the job at 5 this evening, and finally finished two hours later :shock: :shock: :shock:
The problem is that access to the top up plug is very, very limited, I tried a 1/2 inch wobbly, but by the time the plug was half way out the back of the wobbly was fowling against part of the sub frame. In the end I had to cut off the end of an old 1/2 inch socket set extension and then grind it square, total length was 20mm. I used this in a 14mm ratchet spanner to get access and remove the plug. I then used a small hand pump to pump the new oil up into the diff.
What a royal pain in the ****. In the end about a 1/3 of a litre went in.
This is all you can see of the plug!
The tools.
On the job.
Getting the plug back in is just as much a pain, I wedged the plug onto the 1/2 inch bar with a bit of card so that it could be held in place before screwing it in.
The tools.
On the job.
The following 18 users liked this post by RaceDiagnostics:
CharliePar (06-10-2016),
cjd777 (09-21-2014),
Excalibur2012 (09-29-2012),
Flyboygus (11-05-2015),
greenforest56 (11-12-2017),
and 13 others liked this post.
Don't you just love "sealed for life" components.
A.f.a.i.k. the capacity is 1.8 ltr. 0.3 ltr is some leak.
The following 2 users liked this post by GGG:
Excalibur2012 (01-07-2013),
Lufferman (12-21-2014)
aholbro1
08-05-2021 05:02 AM
