Latest dyno update, 524 rwhp (631 HP)
Old 05-09-2012, 12:39 PM
avos's Avatar
Received 1,062 Likes on 759 Posts
Smile Latest dyno update, 524 rwhp (631 HP)
Note this is with a loss calculation of 17%
Here is the link where I keep everything together, and where I also give more info about the run:
https://www.jaguarforums.com/forum/p...e6/#post510598
K.Westra (05-09-2012)
Old 05-09-2012, 01:11 PM
NikasilNik's Avatar
Wow Avos , that's very, very impressive my friend
See you in a couple of weeks time ,
Nik
Old 05-09-2012, 04:25 PM
JagManBonano's Avatar
Will you be placing a video of this in action on youtube??
Old 05-09-2012, 05:11 PM
K.Westra's Avatar
That is awesome. Some day I will upgrade to a '06 XKR with one of these kits. Some day.
Old 05-09-2012, 05:19 PM
OhioXK's Avatar
impressive
Old 05-09-2012, 05:25 PM
oldjaglover's Avatar
Wow! Does all that HP gain come from just the twin screw blower??
Old 05-09-2012, 08:57 PM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
Polite applause is in order
bump!
Old 05-09-2012, 09:00 PM
Reverend Sam's Avatar
Received 1,257 Likes on 563 Posts
I'm drooling.
Old 05-09-2012, 10:44 PM
H20boy's Avatar
Received 1,143 Likes on 749 Posts
always impressed by your engineering avos!
Old 05-10-2012, 12:44 AM
avos's Avatar
Thanks, am amazed myself knowing from where I started, never believed back then this would all be possible, or even that the engine would hold up. Every time I have upped the power a bit was always scary for a while as no one else had this kind of power levels before. I will leave it as is for the coming time, am so happy with how the engine runs/purrs, now I want to just enjoy it for a while.
@Oldjaglover
I have 2 other changes that support these power levels, reground camshafts and sports catalysts, and these allow higher output without having to spin the supercharger faster. The latter is not out of breath yet, and I expect a good gain again by swapping pulleys, but as said, these are serious power levels, and although you determine yourself how fast you want to spin the unit, this is not something I will recommend to do.
Old 05-10-2012, 12:45 AM
xenophobe's Avatar
I'm pretty sure he's running high flow cats and race pipes with pulleys, and a few other tweaks.
That being said, you can probably get somewhere close to his numbers with just his kit.
Old 05-10-2012, 02:24 AM
That IS impressive. I wonder if the bottom end is built to handle all that.
Although...it looks like it's only using up to a little over 6000 rpms. That's nothing for a decent DOHC engine.
Old 05-10-2012, 03:21 AM
avos's Avatar
I am still pioneering here; at least I am not aware of any other setup that comes even close to these power levels (except some others who have my kit, but they are using the maximum recommended power level, so not this one I am at now).
Am driving with this setup already since December last year, so this way I can at least show that that lower power levels with my kit seem very feasible.
But remember, these power levels are for street driving. For track/race usage I always recommend to use a slightly larger upper pulley to lower the power a bit (you could even swap it on the track). Sustained long high power usage is a whole other story then street driving, where within a couple of seconds you are already flirting with local speed limits, and where you have some cooling time between power runs.
Engine is going now to 6200 rpm, if I would extrapolate the figures to 6500, it would be arround 550 rwhp, so it is somewhat tempting. The supercharger itself is only running at 12800 rpm so lots of room there.
For now I will just enjoy, and probably plot a plan for the winter ;-).
Old 05-10-2012, 08:13 AM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Out there in the real world do you have any trouble getting all that power to the ground?
Have you found that other mods to the driveline were necessary, like a LSD, or is it managable with the stock diff and normal size tires?
Really an amazing feat you have achieved.
Old 05-10-2012, 09:31 AM
avos's Avatar
Am still driving a dream, not sure what reality is anymore ;-)
I have a LSD already for a long time, so don't know how it would drive without, but even a stock car could already use a LSD. With my sticky tires (285 wide, going soon for 295) and LSD in 1st you can easily have the wheels spin, no matter what rpm, and no full throttle required. In 2nd it is already more rare and nonexistent in 3rd, however this all assumes a dry sticky road of course, in wet you need to be careful at any speed.
So it isn't that bad actually, and with the clutch type LSD I can even drive safely with traction control on, and take T crossings very fast without the traction control cutting of power for half a second…
Old 05-10-2012, 12:02 PM
Better explain LSD to us 1960's retards.
Old 05-10-2012, 01:17 PM
SteveM's Avatar
Limited Slip Differential.
Old 05-10-2012, 01:22 PM
govatos's Avatar
Avos, have you done anything to strengthen the bottom end, rods, pistons, etc.?
Old 05-10-2012, 01:38 PM
xenophobe's Avatar
LSD will help with this?
What rear end did you drop and how much effort did it take?
Old 05-10-2012, 09:24 PM
Ed M's Avatar
Lightbulb
They don't get it. They're too young.
Quick Reply: Latest dyno update, 524 rwhp (631 HP)
