lean bank
Old 11-16-2014, 04:15 PM
magnum454's Avatar
Cool lean bank
Check eng. lite came on, read codes and got 171 (lean bank 1) How do I correct this? Jaguar is 2000 XK8 4.0 w/57,000 mi.
Old 11-16-2014, 05:04 PM
brgjag's Avatar
Google the error code, it gives you many links back to this very site for the issue and the fixes. Prob have a vac leak or the like somewhere
magnum454 (11-16-2014)
Old 11-17-2014, 12:49 AM
oyster's Avatar
Hi.
Here you go.
Start with simplest first.
Check for an air leak, especially at the "accordion" part of the intake.
Clean MAF sensor with mafsensor cleaner, nothing else.
magnum454 (11-17-2014)
Old 11-18-2014, 04:52 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
The P0171 is for "A" bank and not both banks so for now I would not be looking for a leak. I am thinking you are having a problem with fuel presentation on "A" bank. Get yourself a can of BG44k and add it to your fuel and see what takes place. Your problem could be something other than this but for now try this. You can get BG44k at most dealerships or auto repair shops. Give this a try first.
Gus
www.jagrepair.com
Old 11-19-2014, 07:04 AM
kreyszig's Avatar
+1 on Gus's assessment - a leak would tend to throw a rich code if anything. Being on one side reduces the chance of it being the MAF or fuel filter, so it's likely a fuel problem at the injectors.
Old 11-20-2014, 06:42 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
An air leak causes lean codes, not rich ones, but usually both banks.
Old 11-21-2014, 04:09 AM
kreyszig's Avatar
<facepalm>. my apologies; a leak will cause the engine to run richer (with higher fuel trims)
Old 11-22-2014, 04:59 AM
JagV8's Avatar
Sorry to be pedantic but it tries NOT to run richer or leaner. It tries to add fuel to compensate for the unmetered air to get back to the proper mixture. But yes it will overall tend to run rich since it will add too much rather than too little extra fuel because running lean destroys engines whereas too rich "only" destroys cats, which are cheaper. Ideally it would exactly compensate but leaks aren't so helpful as to be consistent!!
Old 11-23-2014, 10:23 AM
kreyszig's Avatar
no need to apologise, that's a good clear explanation which helped me.
The added fuel doesn't mean it is running rich, another c*ckup on my part!
Old 11-23-2014, 11:57 AM
Sqeeter91's Avatar
clean or swap out your MAF sensor, if you're sure you don't have a vacum leak
CXJ
08-29-2017 08:41 AM
carl purchase
10-14-2015 06:14 PM
sdelliott58
09-28-2015 11:21 PM
Ragn0r
09-19-2015 08:39 AM
Quick Reply: lean bank
