long list of codes..HELP!!!
Old 01-06-2012, 01:43 PM
H20boy's Avatar
Received 1,143 Likes on 749 Posts
lift the car up for a thorough visual inspection and make sure nothing nibbled on any of the transmission wiring
Old 01-06-2012, 04:34 PM
bigvx5's Avatar
well i took the tb plugs loose and plugged them back in,no cleaning or anything yet...did another reset and warmed the car up...drove it around house few times and acout 1/2 mi. up the street..tranmission fault and restricted perf are gone for now..car still not running completely smooth..will rechecked the codes tom to see if any of those changed or disappeared...
Old 01-06-2012, 04:59 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Cleaning and making sure they are clean and tight is important. Do you know if the connectors were ever replaced? I asked earlier about the codes because I recently experienced a P1121 code with a host of many faults. This may be worth reading Jaguar XK8 Throttle Body R&R
Old 01-06-2012, 06:22 PM
bigvx5's Avatar
i really dont know if they have been replaced..looks like the throttle body has some carbon build up..this could be causing the butterfly to not close properly..maybe causing the rough idle and throwing the p0121 code?can i clean this with carb cleaner?
Old 01-06-2012, 06:45 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
I would suggest MAFS cleaner, which you might do at the same time, and the only area that matters is the edges of the butterfly valve and the mating surfaces. Don't waste a lot of spray making it look pretty. All that stuff has got to go somewhere.
Old 01-06-2012, 07:33 PM
Gus's Avatar
Gus
Gus is offline
This is what you need to clean the throttle body Search results for "05078" | CRC Industries When was the last time the plugs were replaced? The car sat for 8 months, try cleaning the TB and then add BG 44K and if it does not clear it up look at the plugs and if that fails let us know. With no codes now it is hard to say.
Old 01-07-2012, 05:00 PM
bigvx5's Avatar
ok..cleaned TB plugs and TB itself..reset the computer and all seems well..no trans fault no restricted perf and seems to be running smoother..still a little rough at idle..warmed it up to operating temp and drove it 3-5 mi.havent checked the codes..will do that again monday..i got long toes i will keep them crossed..
  #28
Old 01-07-2012, 05:53 PM
Gus's Avatar
Gus
Gus is offline
See if you can get the BG44K and add to the fuel. You can get it from most dealerships.
Old 01-08-2012, 10:45 AM
bigvx5's Avatar
i did see something strange yesterday when i was looking at the engine..the serpentine belt is not wide enough..its the wrong belt by two ribs..any thoughts on this causing some if not most of my problems?..
  #30
Old 01-08-2012, 11:11 AM
Gus's Avatar
Gus
Gus is offline
I have not seen or heard that the belt would cause a problem that you have. It could create a problem with your a/c, power steering, charging, cooling and supercharge if it applies.
  #31
Old 01-10-2012, 10:01 AM
bigvx5's Avatar
the trans fault and restricted perf warnings continue to appear randomly...most of the time they disappear if i turn the car on then back on..sometimes i have to do reset..where are transmission electrical connections?i doubt they are visible from the engine bay..do i need to jack car up to find them and where?thanks
  #32
Old 01-10-2012, 02:25 PM
Gus's Avatar
Gus
Gus is offline
What are the codes you are still getting?
  #33
Old 01-10-2012, 04:30 PM
bigvx5's Avatar
i havent rechecked them since i first made the post..it will be saturday before i can get the code reader from my friend..
  #34
Old 01-28-2012, 08:30 AM
BillyRay59's Avatar
Originally Posted by DpezXK8
I have attached a pdf that list most codes you have. Hope you can read it and that it helps. Not a ton of info but maybe more than you had.
This PDF states that it's for the 2003 MY. Can it be used for prior years? Or should I be looking for the same thing for the 1997 MY. Thanks in advance!
  #35
Old 01-28-2012, 08:55 AM
The Coupe's Avatar
I think that most of the codes are probably the same, although the later years may have a few additional codes that the earlier cars don't have.
In any case, I've also got a 1997, and I've attached the diagnostic code manuals below, for both the engine and transmission management systems.
A little light reading...enjoy!
BillyRay59 (01-28-2012)
mrplow58
01-21-2024 05:53 AM
Rivguy
12-04-2020 07:55 AM
Forcedair1
02-19-2020 01:51 PM
1964Daimler
09-09-2015 11:28 AM
Quick Reply: long list of codes..HELP!!!
