Now available: XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit
Old 06-19-2013, 03:29 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Originally Posted by Ophitoxaemia
Can the car be driven without the panels? MadMax Jag?
Yes it can.
  #42
Old 12-31-2013, 02:10 PM
mJohn337's Avatar
I'm torn between attempting some kind of update or add-on to my SatNav to make it useful again, and replacing the screen with the triple gauge cluster. I believe I would rather have the cluster.
So I've ordered a single wood center panel from eBay that appears to be a decent match to my wood grain. If it looks good enough then I will definitly order a gauge cluster and harness. Thanks a lot for making these harnesses available.
  #43
Old 12-31-2013, 04:23 PM
WhiteXKR's Avatar
You are welcome. Let me know if I can help in any way.
  #44
Old 01-04-2014, 05:48 PM
mJohn337's Avatar
Wow, did I get lucky! I found this center dash panel on eBay, and took a chance that it might match. It's about as perfect as I could expect- the color and burl pattern are nearly indistinguishable! The dash wont be sequenced matched any more, but it will hardly be noticeable. (This panel was actually listed as being for an XJ8, but I knew better by the looks of it- it was for an XK_).
I've placed my order on the gauge cluster, and will order one of those wiring harnesses shortly. I plan to have a local audio shop do the install for me, and I am going to keep all of the original nav equipment and panel.
So far the panel has cost me $60, the gauge cluster $50, and the harness is like $90. Maybe 2 hours of shop time and this will all total about $300.
Attached Thumbnails Now available:   XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit-2014-01-04-17.16.16.jpg   Now available:   XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit-2014-05-14-11.17.49.jpg
  #45
Old 01-04-2014, 06:33 PM
WhiteXKR's Avatar
Sweet! That is one of the best random matches that I have seen.
When you order the cable I'll throw in a couple of spare bulbs for your gauge cluster. They often go out on the used clusters from all the handllng.
  #46
Old 07-11-2014, 06:14 PM
newXKRguy's Avatar
Default Just ordered the harness and gauge cluster
I just ordered the refurbed gauge cluster and wiring harness from Steve, along with three small chrome instrument rings from Adamesh and a what looks like a really close match for my dash center veneer from eBay. Can't wait to get it all together and finally have the xkr I've dreamed of. I'll keep you guys posted on the progress.
Best Regards, Fred
  #47
Old 08-17-2014, 07:14 PM
newXKRguy's Avatar
Default Here it is
Here's a pic of my completed install. Everything went perfect. Misc wood trim match looks really decent in person. Three gauge cluster ordered from JagWrangler is in perfect condition. A big thanks to Steve is sending the gauge cluster with the chrome needle heads that match my instruments. RealGauge with oil pressure is on order now.
I'm a happy camper.
Rgds, Fred
The following 2 users liked this post by newXKRguy:
Norri (08-18-2014), Salo (06-08-2017)
  #48
Old 08-18-2014, 08:42 AM
WhiteXKR's Avatar
I'm a happy camper.
Rgds, Fred
Thanks for posting Fred...it looks great. Even though I run an upgraded nav. system and on screen electronic gauges in my own XKR, I always get a little jealous when I see the the 3-gauge upgrade...it is so much classier and more pleasing to look at.
  #49
Old 08-18-2014, 11:19 AM
mjlaris's Avatar
I also run a upgraded navigation system but I have to admit this is one of the nicest 3 gauge cluster conversions I've seen.
Mark
  #50
Old 08-18-2014, 08:58 PM
newXKRguy's Avatar
Thanks Steve, I saw your electronic gauge setup and I have to say it looks pretty trick. My RealGauge arrived today, but I don't know when I'll find time to install it. Soon, I hope!
Best Regards, Fred
  #51
Old 08-18-2014, 09:03 PM
newXKRguy's Avatar
Thanks Mark. I'm really pleased. Once I get the RealGauge upgrade installed, it'll be time to move on to the center stack to install an iSimple interface for my iPod. It never ends (fortunately).
Best Regards, Fred
  #52
Old 12-28-2014, 11:05 PM
Excalibur2012's Avatar
My biggest frustration is finding a center fascia that matches the RH & LH panels. Mine is beautifully dark & got one that was close but still far enough off to look obvious. The only full panels I see are so ugly, no wonder they were dumped. I look at some of the panels with big yellow swaths and wonder how they ever got past QC to begin with.
  #53
Old 12-29-2014, 08:14 PM
WhiteXKR's Avatar
Be patient and keep a search running on ebay (click on 'follow this search' at the top of your search results page). A worthy example is bound to show up eventually.
  #54
Old 08-05-2021, 12:29 PM
BigAlBre's Avatar
What about replacing these guages with after market units like Stewart Warner? What is the guage size of the originals?
  #55
Old 06-07-2023, 11:59 AM
AArt's Avatar
Default Conversion Harness Kiot
A RHD version is now available.
Are you still selling these and if so can I buy one. I am in the UK.
  #56
Old 06-08-2023, 08:16 AM
WhiteXKR's Avatar
Yes we are. Go to https://www.thejagwrangler.com/xk8--...onversion.html
99xk8guy
09-21-2019 07:34 PM
jagtoes
09-09-2015 09:56 PM
giandanielxk8
09-06-2015 07:21 PM
sklimii
09-05-2015 06:04 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Now available: XK8 / XKR Navigation to Triple Gauge Cluster Conversion Harness Kit
