OBD2 wont communicate with my car
Old 04-15-2014, 10:41 PM
jaglenn's Avatar
Default OBD2 wont communicate with my car
Last week I found that the OBD2 was not able to communicate with my car. I ordered a used instrument cluster in effrot to correct this issue, it arrived today. I installed it and nothing is different. so is it time for a new ECU/rebuild? I do know the ECU has been changed, infact I got two others with the car. If im going to get it rebuild I'd like to have the factory ECU back in the car... IS there anything else to check before spending 600 bucks to help the OBD2 communicate? or is it time to break out the wallet? and how might I tell which computer is the "right" one.
Old 04-16-2014, 01:11 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Even if changed, it should communicate. Chances are you have some basic wiring/fuse/etc fault.
Old 04-16-2014, 02:33 AM
GGG is offline
Received 16,798 Likes on 12,167 Posts
Originally Posted by jaglenn
Last week I found that the OBD2 was not able to communicate with my car. ...........
2 other ECU's came with the vehicle!
Does this indicate it has unresolved module 'history' which you are trying to fix rather than being a new fault suddenly developed on a previously correctly functioning vehicle?
Old 04-16-2014, 03:10 AM
jaglenn's Avatar
Yes, I bought the car not running and no history... starting from scratch trying to work through it.
here's the rest of the story...
https://www.jaguarforums.com/forum/x...8-198k-115309/
https://www.jaguarforums.com/forum/x...p-fuse-115361/
Old 04-16-2014, 05:11 AM
GGG is offline
The VCATS label in the luggage compartment lists the serial numbers of the modules originally fitted to the vehicle. It's behind the carpet next to the battery:
From this you can work out which modules are original and which have been replaced. If you do have to have one or more rebuilt, preferable to go with the original matched ones.
When you say "OBD2 was not able to communicate with my car" do you mean the DLC (Diagnostic Link Connector) is dead?
Old 04-16-2014, 05:35 AM
jaglenn's Avatar
When I connect my scanner, it says it cant establish communication. So yes it's "Dead"
Old 04-16-2014, 05:45 AM
GGG is offline
Both DLC fuses OK and your scantool known to work on XK8/XKR?
Old 04-16-2014, 01:07 PM
jaglenn's Avatar
All fuses in that pannel are good and I veriffied voltage.
Scanner is an Innova 3100 several people on this board have the same and are getting results with it.
as far as the vcats sticker if it was ever there it has been removed... sorry to say my car has 200k on it, I'm afraid the last few year it was most likely not treated very well (4 previous owners in the last 3 years)... I'm hoping to undo that.
Old 04-16-2014, 04:57 PM
JagV8's Avatar
Maybe meter the wiring at least from DLC to PCM connector? Another cause of failure to communicate can be a module that's bad thus hanging the related wire(s) so do as many tests / unplug modules as you can. But go with any ideas Graham has...
Old 04-16-2014, 08:38 PM
jaglenn's Avatar
I think I found the problem....
Old 04-17-2014, 05:05 AM
GGG is offline
That removes all doubt - definitely not a rebuild candidate!
Any Jaguar Dealer can print off the original factory build sheet from the Direct Dealer Warranty System. This has all the info which would have been on the VCATS label.
Dealers in the UK are usually quite co-operative with such requests for information but I know from posts on the forum US Dealers have what can only be described as a bizarre approach to customer service and may not be so helpful.
With either of you spare modules plugged in, is there any sign of life in the DLC?
Old 04-17-2014, 09:29 AM
JagV8's Avatar
Horrors! Got a water leak, cowl maybe? Is it now fixed?
Old 04-17-2014, 01:18 PM
jaglenn's Avatar
That was one of the replacement ECM's that came with the car...3 of them.
It was installed.. but not the factory one. I not necessarily a leak in MY car but it was definite water damage. I have opened the other two and the one I believe is the OE has a leaking capacitor, no visible damage to the third. I'm going to pop the last one in and see if it will communicate with my OBD2. but it's currently raining.
Old 04-17-2014, 02:34 PM
jaglenn's Avatar
Okay,
I installed the "spare" ECM still no communication with the OBD scanner.
I'm off tomorrow and Saturday hope it's not raining.
Old 04-17-2014, 03:20 PM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
I sent my ECU to ASI and they did a great job.
Old 04-17-2014, 06:59 PM
Default Ecu
Doesn't the ECU have to be formally coded to the car? My understanding is that if this isn't done a new ECU won't work. Some kind of a security feature.
Old 04-17-2014, 07:49 PM
jaglenn's Avatar
That is my understanding as well, however even if it was wrong it SHOULD allow the high speed network to function and that is not happening now.
Old 04-18-2014, 02:20 AM
JagV8's Avatar
Yes, should have OBD comms. (And then codes for anti-theft etc.)
There again, when as bad as that damaged one it might allow/prevent just about anything
jaglenn (04-18-2014)
Old 04-19-2014, 04:38 PM
jaglenn's Avatar
For good measure today I decided to pop in ECM number 3 (remember my car came with 2 extras) and I KNOW this one has a bad capacitor that has leaked on the board. I figured how much more damage could I do. When I reconnected the battery the fule pump powered up the throttle body woke up and the OBD2 scanner talked to the car. It actually even fired and had there been gas in the tank I believe it would have fired up.
I even got some codes out out of it...
p1638
p1642
p1000
p1637
p1643
Old 04-19-2014, 04:46 PM
jaglenn's Avatar
P1000 OBD Systems Readiness Test Not Complete
P1637 CAN Link ECM/ABS Control Module Circuit/Network
P1638 CAN Link ECM/INSTM Circuit/Network
P1642 CAN Link Circuit
P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network
Looks to me like it's saying the CAN is screwed.
But it is doing more now that it has since I got the car.
Quick Reply: OBD2 wont communicate with my car
