Paint and Trim Codes
Old 07-13-2009, 02:52 AM
Jag Convertible's Avatar
Default Paint and Trim Codes
Hi, I have a 2002 XK8 .I"m pretty sure that the paint and trim codes should be on this sticker but they're not there.If anyone has a car with the same paint or interior trim color can they please tell me the code numbers and what the colors are called.I think the paint is called Sapphire but not 100% sure ?. I need to do some paint work and use leather dye on some worn areas.Paint and Trim Codes-l4.jpgPaint and Trim Codes-205_0588.jpgPaint and Trim Codes-l1.jpgPaint and Trim Codes-img_9779.jpgPaint and Trim Codes-img_8205.jpg
Old 07-13-2009, 06:38 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
Default 2002 Paint and Trim Codes
Looks a lot like mine. The trim code is NED and the paint is JHM. According to JEPC they were called Ivory and Pacific.
I wonder if your car was originally delivered somewhere other than the US.
Attached Thumbnails Paint and Trim Codes-jaguar-2002-paint-color.jpg   Paint and Trim Codes-jaguar-2002-vin-label.jpg
Old 07-13-2009, 07:07 AM
Thanks so much test point. My car is a right hand drive and was in England from new and then privately imported to Australia in 2006. Your car definitely looks the same color as mine.
Cheers.
Old 07-13-2009, 09:44 AM
GreenJewel's Avatar
Cheers.
I was at a local Jaguar dealer and showed them my ownership papers and with that they used the vin number and they gave me a print out of the date that the car was dispatched from Jaguar, put in use, paint and trim color and trim items such as: part Leather Trim, Halfwood steering wheel, sable parcel shelf, sable/chasmere facia, oatmeal headlining, sable carpet, twin needle stitching, sable seat belts, cashmere stitching, oatmeal upper, burl walnut veneer, charcoal welts. A full set of serial number excluding the CATS radio number. It shows the differential number, drivers airbag engine number and a mess of other numbers (won't list to keep this short). Plus all of the equipment such as garage door opener, premium sound, space saver spare, F8 R9x18 7 flute wheels etc.etc.
They can give you the correct paint code numbers for the above if you car looks a little different than test points car. I hope this helps you.
Old 02-17-2012, 04:40 PM
ji9988's Avatar
Hi Testpoint, I have the same color codes as you am I correct to assume the carpet color is sable? I'm looking to get some custom floor mats. Thanks!
Old 02-17-2012, 06:15 PM
test point's Avatar
Sable would be a good word choice but I am unaware of a trim code list that goes beyond paint and leather. As posted above any dealer can print out a build document that gives all the fine details of how the car left the factory.
Old 02-17-2012, 06:22 PM
GGG is online now
Received 16,761 Likes on 12,150 Posts
My last 2001 XK8 was JHM (Pacific Blue) with NED (Ivory) trim:
Paint and Trim Codes-2001-xk8-front.jpg Paint and Trim Codes-2001-xk8-4.0-os-interior.jpg
I have the same dealer printout for the car as Green Jewel describes and the carpets which look the same as yours were Sable.
Old 02-18-2012, 08:42 AM
ji9988's Avatar
Thanks!!
Rivguy
12-04-2020 07:55 AM
wcourt3010
11-03-2015 04:10 PM
Adam Lueb
09-28-2015 02:54 PM
OkieTim
09-08-2015 04:48 PM
TexasCat
09-08-2015 04:36 AM
Quick Reply: Paint and Trim Codes
