Ripped off
Ripped off
I had a guy in atlanta ga, to replace my hoses for my convertible top, cost me 1500. After he so called repaired it, it was slow to go up and down and now it won't work at all, I called him to tell him my problem, he quoted I only replaced the two main hoses, it may be the other ones broken now. He told me he replaced all my hoses, guess now I am without a top working, what to do now.
Welcome to the forum, although not under the best of circumstances. You say it would only go up and down slowly, but was there any fluid under the car, indicating leakage? It may just be low on fluid. Whatever the reason, best stay away from Marvin. If you are in the Atlanta area I would be willing to take a look at it and see if anything obvious is wrong. I'm not proposing to do any repairs, just an inspection.
Firegirlpam, give RJ a chance to look at what you have. If nothing else he can steer you in the right direction.
Sorry about the RIP OFF.
Wayne
Wayne
The following 2 users liked this post by cjd777:
Firegirlpam (07-27-2014),
RJ237 (07-26-2014)
theres a good jag mechanic in douglasville called wizard automotive he'll know what the problem is .
+1 for Wizard. But I'm thinking it might be simple and may not require an appointment at a shop.
Firegirlpam, I'm going to send you a private message with my phone number if you want to talk.
The following 2 users liked this post by RJ237:
JimC64 (07-26-2014)
Top
Sure, that will be fine to send me your number, I need advise, thanks
Top
Sure I will give RJ a chance, thanks
Received 4,175 Likes
gear box fault is a possible transmission fault but before thinking worst case scenario, how old is your battery??? Are you getting any other indications?? Weak batteries can give all kind of weird faults and indications. Advance Auto or Autozone can check your battery and charging system for you at no cost
The following 2 users liked this post by sklimii:
Firegirlpam (07-29-2014),
RJ237 (07-27-2014)
If the battery checks out, have them read the codes. I'm not sure the generic readers they use at the stores will show all transmission codes, and any codes that are displayed should be written down and reported here for interpretation. The store reader explanations are often incorrect.
This looks like it may be useful.
MERCEDES BENZ W210 722.6 FACTORY TRANSMISSION REBUILD SERVICE REPAIR MANUAL CD
Do you have anything in writing indicating that all hoses would be replaced? If not you just got ripped off and lesson learned. If you do than take him to small claims court.
At the lest file a complaint with the better business bureau and the state agency that regulates comerance.
Maybe I read too fast, but did you have a chance to check that the Petcock on the pump is fully closed? You wouldn't be the first of us to miss that.
Projects still to go are a transmission fault that may be a sensor, have to get a Merc trans. repair manual, and a C 1095 abs code, of which I have repaired several.
One code that I am unable to track in JTIS is a U1261( if I remember correctly). When I try to look at U codes it shows B codes.
I have a console switch I got when I bought a wood shifter surround out of a wrecked car. I'm a long way off, but it's free if you want it.
No idea about functionality since I have a coupe, but I can check it with the multimeter tonight.
Drop me a PM if interested.
The following 2 users liked this post by ccfulton:
RJ237 (07-28-2014)
I am interested in the switch, may I pay u for it and have you to mail it to me, thanks
Send me your address and I will mail you the money to ship the switch part, thank you
I paid $540 for both hoses that go to the front latch and just over $400 for the hoses going to the lifts and that was the revised hoses and also included shipping from Gaudin Jaguar. It was just over $950 total for all hoses, if you paid $3000 you were SERIOUSLY ripped off. It took me just over 6 hours to do mine and that included me reversing the fron two hoses and having to redo those.
Last edited by Norri; 12-09-2014 at 01:06 PM. Reason: Removed quote from banned member
