Seat Power / Heated Seat
Old 01-21-2013, 11:14 AM
2ndxk8's Avatar
Default Seat Power / Heated Seat
Seat power to my drivers side seat stopped working weeks ago. Low priority cause its adjusted nicely for me. Headrest and lumbar power OK. Passenger side OK too.
Just last night found that heated seat for driver is not working also. Passenger side OK.
Is this any indication for what may be wrong? Are they related?
I checked fuses for seat power but they are not blown.
Any help appreciated.
2x
Old 01-21-2013, 11:42 AM
Jon89's Avatar
Received 4,275 Likes on 2,812 Posts
Keep in mind that it can sometimes be difficult to see if a fuse is indeed blown. I would install new fuses and then see if your seat will move as a first step....
Old 01-21-2013, 12:01 PM
stevepaa's Avatar
does the light go on at the heated switch button?
do you hear a click from the under seat module?
Old 01-21-2013, 12:31 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
Seat operation and seat heat are both handled by the seat module which are famous for failures. If one works try swapping it with the other.
Old 01-21-2013, 01:36 PM
2ndxk8's Avatar
Stevepaa
No sir. No click and no light for the seat heater.
Old 01-21-2013, 02:39 PM
androulakis's Avatar
Seat module....
You can DIY if you're good with electronics...
Have a look here...
https://www.jaguarforums.com/forum/x...-module-73372/
Take care,
George
Old 01-21-2013, 06:10 PM
stevepaa's Avatar
+1 seat module
adam699
09-12-2015 05:32 PM
Clamdigger
09-12-2015 03:43 PM
Quebecjag
09-10-2015 06:06 AM
joey g
US Northeast
09-07-2015 06:28 PM
Dallas XK8
09-03-2015 12:17 PM
Quick Reply: Seat Power / Heated Seat
