Short Whine on acceleration
Old 08-25-2012, 11:15 AM
Stamford's Avatar
Question Chisel?
Originally Posted by steveinfrance
+1 on the lift.
The easiest way to start stubborn screws is with a small cold chisel + hammer.
I'm curious. How do you position the chisel. Is is supposed to act like an impact driver?
Old 08-25-2012, 12:56 PM
Jon89's Avatar
Received 4,275 Likes on 2,812 Posts
Stamford,
How many miles on yours?
Old 08-26-2012, 10:52 AM
Stamford's Avatar
82,000 miles and change. Runs like a top but I imagine the trans fluid is reaching the end of its useful life. And since I have the bark, I assume it's the original "good for life" fluid in there. Do wish I had a lift, though.
Old 08-26-2012, 11:17 AM
steveinfrance's Avatar
I should post a picture but it's getting late.
These Torx screws have a big flat head so put the chisel on one side of the head, angled at 45° and (obviously) pointing in the 'unscrew' direction, then give it a smart tap with a medium weight hammer.
It is indeed similar in effect to an impact driver but, with these screws, the force is applied on a much larger diameter than with a Torx bit so is more effective.
Old 08-26-2012, 11:31 AM
Received 4,436 Likes on 2,421 Posts
Shot a vid on the way home from Mollis, yep mine has the bark as well....
Old 08-26-2012, 11:57 AM
Stamford's Avatar
Are you placing the chisel on the outer edge or inside the torx pattern? Having seen the hassles Sam had with the screws, I am hoping my car has the bigger screws but even those could be good and stuck.
Old 08-26-2012, 01:03 PM
On the 'flange' of the screw right outside the tiny Torx pattern. That way you get enormous purchase.
Stamford (08-26-2012)
oldjaglover
04-01-2020 05:04 PM
Johnken
04-08-2018 10:21 AM
mat32essex
10-03-2015 04:12 PM
Poet
10-02-2015 09:00 AM
Quick Reply: Short Whine on acceleration
