Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Starting problem - Inertia switch?
LinkBack Thread Tools Search this Thread
Old 07-13-2012, 06:17 PM
andyps's Avatar
Default Starting problem - Inertia switch?
Just over a week ago a car ran into the back of my XK8 whilst I was stopped at traffic lights, not too much damage fortunately but it will be needing a new rear bumper. Shortly afterwards it felt like it wasn't going to start but then did and ran perfectly. Now, to get it to start I generally have to press the accelerator a little and it can take while to fire. I took it to have a diagnostic check to see if anything showed up (initially there were a few things so they were cleared and I went back today, a couple of days after they were cleared) and there were two things, one is that the catalytic converter on one bank is performing below requirement, possible cause is fracture so hopefully that is going to be replaced under insurance. The second was in the "flight recorder" test which showed that the inertia switch had been activated. It was something I had wondered about but my knowledge was that they were either on or off, and mine is certainly pressed down as it should be to run. Could it be that it is slightly sticking or might there be something else causing the problem? Obviously need to get it sorted but would be good to get this done quickly and I'm quite prepared to have a go myself if it could be something straightforward to fix. Anyone got any ideas?
__________________
2003 XK8 4.2 Convertible
Old 07-13-2012, 07:41 PM
GGG GGG is online now
Photobucket
Send a message via Skype™ to GGG
At least you should have no problem with the insurers with someone running into the back of a stationary vehicle at traffic lights.
Inertia switch is a safety device and is either ON or OFF. It has to be reset manually. If it had tripped in the accident you would have had to reset it. Flight Recorder only tells you it has tripped but not when.
Did they give you the actual 'few codes' before clearing them and the further codes when you went back? The actual codes - not what they described them as.
__________________
2007 XK 4.2 Coupe
We have a WINNER in the PINNACLE WAX Giveaway.
Follow this link to the results:
http://www.jaguarforums.com/forum/de...1/#post1174291
Old 07-13-2012, 08:13 PM
andyps's Avatar
That is what I thought about the inertia switch, and it didn't activate when the car was hit. Just seems odd that it was showing in the flight recorder status.
Most of the codes which showed up related to when I had coil pack fail a few months ago, they showed them being unplugged whilst I found the failed one. I have a print out of it but not to hand.
The only fault now showing is the catalytic converter not working to requirement, it says which bank and gives possible causes including fracture so the insurance company have said they will replace it.
__________________
Old 07-14-2012, 04:56 AM
Photobucket
Possibly the switch has been triggered sometime before you got the vehicle.
They unplugged coils to find a failed one? The usual method is to move the suspect one and recheck DTC's to see if the code changes to match (each cylinder sets an individual code).
With a damaged Cat, the fuel trims will be all over the place. The problem will very likely to disappear with a replacement Cat and a hard reset.
__________________
2007 XK 4.2 Coupe
Old 07-14-2012, 02:26 PM
andyps's Avatar
Thanks for the reply Graham.
I was the one who unplugged the coil packs to find it myself, pretty easy to do really when one cylinder is down and saved another drive to a place to have the codes read when it wasn't running properly.
What do you mean by a hard reset?
__________________
Old 07-14-2012, 02:57 PM
Photobucket
Not a good plan to run with a deliberate misfire. You need a code reader at minimum with these vehicles.
A 'hard reset' removes (almost) everything form memory, particularly fuel trims.
Disconnect the battery negative terminal, and short it to the positive terminal for 30 seconds to reset the electronics.
__________________
2007 XK 4.2 Coupe
Old 07-14-2012, 04:49 PM
andyps's Avatar
On the basis it already had a misfire and I needed to sort out what it needed as quickly as possible (and I'd only had the car about 3 weeks at the time so hadn't even considered a code reader at that stage) disconnecting a coil plug for a couple of seconds to see if it affected the running.
Thanks for the info on the hard reset.
__________________
Old 07-15-2012, 03:49 AM
H20boy's Avatar
Running with a misfire for a few seconds, minutes, or even a couple days (short drives) shouldn't do any longterm damage, but extended misfires sends too much fuel to the cats and plugs them up, if you want to see if it truly is your cat, then with a normal OBD2 scanner, you can monitor the voltages, if you're downstream sensor (B1s1 or B2S2) is over 1 volt (if i remember correctly) its showing the cat damage. I've seen two cat's with this problem, and one S2 sensor was reading 0.7v, the other was like 1.9, or higher. Swapping it with the other sensor on the other bank resulted in the same cat voltage spike, meaning it was the cat, and not the sensor itself being bad.
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 07-15-2012, 10:50 AM
Beav's Avatar
A damaged cat will not affect fuel trims. Trims are only affected by upstream sensors. Cat efficiency is only determined by downstream sensors.
__________________
Certified Master Auto Tech, Master Truck Tech, Emergency Vehicle Tech (CMAT/L1, CMTT, CEVT) Factory Trained Ford, GM, Isuzu & SAAB Tech. Currently responsible for large metropolitan fleets of Fire Trucks, Fire Engines, Fire Boats, Ambulances, and various rescue equipment. Forty-four years of dirty hands and lots of head scratching.
Kentucky Colonel
'98 XK8 'vert
Tags
1998, 2003, activation, car, inertia, jag, jaguar, location, start, starting, switch, trip, xj8, xj8l, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
