steering pump removal
Old 03-25-2015, 03:38 PM
Autobahn kid's Avatar
Default steering pump removal 03 xk8
Would anyone have a pdf file on removing the power steering pump on a 4.2L xk8?
I am attempting to fix a 2003 and a friend next door is replacing leaky seals on his front timing cover.
Both of us are stuck at the pump removal. It seems that the pump's mounting bracket bolts go into the timing cover.
thank you
Old 03-26-2015, 09:17 AM
RaceDiagnostics's Avatar
I had a look at my pdf (too bid to post), it just shows two bolts on the top and two below, it just says, "remove the bolts".
dsnyder586
04-04-2019 02:38 PM
Dicque
09-19-2015 12:53 PM
sogood
09-15-2015 07:35 AM
kstevusa
09-07-2015 01:12 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: steering pump removal
