Throttle Body Cable Adjustment = Original Power Restored ?
Old 07-01-2010, 02:59 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
Default Throttle Body Cable Adjustment = Original Power Restored ?
Originally Posted by Gabriel
I was playing around with my ELM 327 Bluetooth OBDII scanner paired to my LG incite watching live data stream paying attention to the throttle position and I noticed when the gas pedal was on the floor and the kick down switch was depressed max throttle position was at 85% . So I removed the center cover above the throttle body and adjusted the slack out of the cable now I have 100% throttle and what a difference.
Take off the plastic cover by the windshield in the engine bay. Cut the zip tie and pop out the square plastic holding the cable in the metal braket. Twist the square counter clockwise and put back in. Don't forget to put a new zip tie around it to hold it in
If you tighten it a little and put it back while the engine is running you can see if there is too much or too little based on the engine speed. I don't have a scanning tool but doing it seat of pants made a pretty big difference. The car is much more responsive.
Originally Posted by kris
Thanks...much appreciated. What a difference! And the down-shift is easier to attain without mashing two feet on the gas pedal!
Originally Posted by CTLS
Checked my 2000XJR and was the same...what a difference with 100%. Thanks for the post!
Originally Posted by SHOFZR
I have had my "R" a little over three years now and have never been disappointed by the performance, but now with 100% throttle I have fallen in love all over again..
Originally Posted by brutal
You can and should make sure your throttle cable is adjusted with little to no slack so that you have good pedal to throttle response as the cable gets streached over time
The following 8 users liked this post by H20boy:
Alvin Burns (03-18-2011), Domingo (01-24-2014), dsetter (01-20-2011), Joe Enge (04-09-2020), multijag (09-02-2017), Nola-Jag (11-20-2013), reb1999 (12-03-2014), Virgo (03-23-2012) and 3 others liked this post. (Show less...)
Top Answer
07-02-2010, 12:22 PM
Reverend Sam's Avatar
Reverend Sam
Reverend Sam is offline
Received 1,259 Likes on 564 Posts
I just checked mine, and there was definitely some slack in the cable. The throttle position sensor didn't go all the way to the stop when the pedal was floored. I adjusted it and made a video which I will post shortly. Mine is a 2003 and I think it may be different than earlier years. I didn't see a zip tie or anything. There is an adjustment on the cable and you basically pull off a little clip, slide the cable out, and reinstall the clip. It's hard to explain, but just watch this video:
http://www.youtube.com/watch?v=AV8iF6SMjh8
By the way, the next time I clean my engine compartment I'm going to take off those two covers and clean under them. Forgive me for all of the dirt.
Old 07-01-2010, 07:03 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
There is a cable to the 'throttle position sensor'. It's electronic from there.
Old 07-01-2010, 11:17 PM
H20boy's Avatar
I would really like to know the 'adjustment' procedure, my pedal=>throttle is a little sluggish, I thought that was just normal.
Tony Vasquez (10-13-2023)
Old 07-01-2010, 11:32 PM
DaleD's Avatar
Location: Marin County, CA, USA - Just north of San Francisco
I remember reading something about this on the "other" forum. Here it is for whatever - I haven't tried it:
: SHOFZR on 2010-04-23 at 22:01:02(posted from: Host: 99-67-115-135.lightspeed.rcsntx.sbcglobal.net IP: 99.67.115.135) Subject: 100% Throttle??? (258 views) (394 thread views) Message:
A couple weeks ago, I was playing around with my OBDII scanner looking at the throttle position readout and noticed when the throttle pedal was on the floor (kick down switch depressed) I was only at 85%, adjusting the throttle cable until I got 100% made a big improvement. Several others on the XJ8/XJR side checked their throttles and noticed the same situation one thoughtful enthusiast Gabriel suggested I share with all Jaguar lovers. Attached is the link to my original post.
Cheers,
Adrian 2000 XJR
http://forums.roadfly.com/forums/jag...9476089-1.html
Link:
Best, DaleD
wcnesta (05-24-2012)
Old 07-02-2010, 01:48 AM
H20boy's Avatar
Great memory Dale, it was a good read. I've added some quotes from that forum over here, with their respective authors. Thanks for linking this one!
A good project for the weekend. Don't forget to update if anyone does this to their car.
Old 07-02-2010, 10:26 AM
SeismicGuy's Avatar
This is an interesting discovery and, indeed, with other cars I have owned that had the cable going all the way from the pedal to the throttle (or carburetor), I frequently noticed that there was too much slack sometimes and I would adjust this out. I did not realize this was also the case for drive-by-wire setups and, as always, if someone has some photos along with a good description of the procedure, that would be another great addition to the FAQ section.
Doug
Old 07-02-2010, 12:22 PM
The following 13 users liked this post by Reverend Sam:
akc70 (01-25-2015), billm (04-01-2011), Clamdigger (05-26-2012), D. Fite (12-27-2014), Flighty (09-16-2014), howdoyousayjaguar (04-11-2015), JagTheRipper (11-15-2011), Jim D (09-14-2014), Joe Enge (04-09-2020), jrb53 (06-24-2015), Virgo (03-23-2012), wcnesta (05-24-2012), XK8+XJ8L (12-01-2010) and 8 others liked this post. (Show less...)
Old 07-02-2010, 12:39 PM
OH MY LORD! That's what I'm talkin' about! I just took it for a drive with the newly adjusted throttle cable. I think I added 50 horsepower!
Old 07-02-2010, 01:00 PM
Goldlion's Avatar
Rev Sam: Thanks for the video. I watched and then stepped out to the garage and did the check on my 2005 XKR and sure enough there is about one half inch of travel remaining when the throttle is fully depressed. I will be adjusting shortly.
Are any of the Jag Techs out there familiar with this finding and if so do you have any cogent advice?
Regards
Tim V.
Old 07-02-2010, 03:19 PM
On mine it seemed as if some days the car would absolutely haul ***, and other days I would mash the throttle and it would be like "meh...". I think a part of it has to do with temperature. When the car has been sitting in the sun on a hot day the throttle cable will lengthen due to the heat. When the car has been sitting overnight on a cool night, the cable will shrink. My "awesome" driving experiences were probably on cooler days when I first pulled it out of the garage. My "meh" experiences were on super-hot days when the car had been in the sun. I know a hot day can reduce engine power just from the heat, but I'm sure the cable length played a role, too.
Over the weekend I think I'll adjust the cable again after the car has been sitting in the sun for a few hours. Maybe I can pull one more notch out of the cable.
Old 07-02-2010, 05:15 PM
MidlifeXJR's Avatar
That's cool Sam, when I get my XJR back from the detailers I'm going to check it out as well. I have had the exact same thought that on some days the car performs great and others it seems sluggish.
Old 07-02-2010, 05:57 PM
MarcB's Avatar
Sam thanks for the video It was a great help for those of us with 4.2 litre cars - I was wondering why my XKR seemed to had lost a little life. I did the adjustment and it accelerated like it did when it was new. - The only issue I have now is the fact that pedal is now higher than it was before and does not align with the break pedal. Has anyone else experienced this? Is there an adjustment for the pedals? I'd though i'd ask before I went dash diving bad back and all.
Old 07-02-2010, 06:25 PM
My pedal is a fraction of an inch higher, but I drive several different cars so I have to get used to the pedal placement each time I switch. The change in pedal position was barely noticeable to me. How many notches did you move the cable?
Old 07-02-2010, 06:52 PM
MarcB's Avatar
I moved approx. 4 notches, I tried to remove all the play I could. After the last post I moved it back a notch which helped with the pedal alignment but it lost some throttle response. I guess I will adapt to the new pedal position because the response make a noticeable difference. Thanks again for the video - it made it super simple - Thank Megan for me too.
Old 07-02-2010, 06:59 PM
H20boy's Avatar
I couldn't wait to get the car home after work and do this adjustment, thanks Sam for being the first to do it on here and showing us the correct procedure!
I'm more scientific about it, and can give you some actual numbers to quantify the before/after results...I'm amazed. I used my AE software to monitor the pedal position sensor, and the throttle position sensor during the adjustment.
Before
A pic of the throttle body, with the WOT engaged...disappointing indeed.
Here is a screenshot of the pedal/TB sensors, fully depressed w/o WOT engaged
---> WOT engaged ... a measly 79%!
Made the adjustment to the cable, I got 2-1/2, almost three notches out of the cable, and I didn't really pull on it...just till it felt taught.
After
The throttle body visually is open SIGNIFICANTLY more, but how much you ask?
Pedal depressed all the way, but not WOT...yet
---> Now, WOT engaged... WOoooHOOOO...100%
= 21% increased throttle opening!!
Just to check my 'pedal at rest' numbers, I ran the scan without any pedal actuation... all seems well.
As to my pedal position, it seems unchanged from the drivers seat, perhaps you guys went maybe a bit too much on the adjustment? I won't test out the new 'power' until this rain stops. My luck, I'll end up 'on the wrong side of the hedge'.
Someone should tell the S-typers and the XJ owners. (those R guys are going to love this test).
The following 2 users liked this post by H20boy:
Kyotoboy (01-04-2011), wcnesta (05-24-2012)
Old 07-02-2010, 07:21 PM
MarcB's Avatar
I wish I had the AutoEnginuity scan tool to adjust it more precisely but all I can say is this "R guy" is ecstatic. Thanks to all!
Old 07-02-2010, 07:24 PM
That's awesome! I didn't look inside the throttle to see where the butterfly valve thingy was, but I'm guessing it was similar to yours as I also got three notches out of the cable. I need to get whatever software that is you are using.
And perhaps this should be added to the FAQs.
Bob OB (04-11-2013)
Old 07-02-2010, 07:34 PM
Paul Pavlik's Avatar
FWIW, I checked my car (with the earlier cable setup) and the setting was perfect from the factory.
Old 07-02-2010, 07:35 PM
MarcB's Avatar
I guess I should have removed the intake to see the throttle posititon but it is 112 degrees here right now so garage time was kept to a minimum.
Old 07-02-2010, 08:56 PM
test point's Avatar
I don't think I have ever had to occasion to get to WOT. Too many curves/hills.
Quick Reply: Throttle Body Cable Adjustment = Original Power Restored ?
