Tinny Rattle From Rear of Engine
Old 01-28-2015, 05:28 AM
ukdude's Avatar
Question Tinny Rattle From Rear of Engine
Hi. My 2000 XK Coupe has started to show signs of a short, tinny rattle from the right rear of the engine when the revs are flipped up and down to and from about 1500 revs. Should I be worried enough to rush to a jag hospital?
Any ideas would be appreciated.
Old 01-29-2015, 06:33 AM
RaceDiagnostics's Avatar
I have something similar but only for the first minute of warm up then it goes. I have a thread on it from about a week or so ago, unfortunately no conclusion.
I'm going to try to get over to an indie to let them listen sometime soonish, but since the car has been doing it for about 2 years now, I'm not in a big rush.
ukdude (01-29-2015)
Old 01-29-2015, 08:06 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Is it a rattle or a chatter?
Old 01-29-2015, 09:58 AM
Gus's Avatar
Gus
Gus is offline
Old 01-29-2015, 12:05 PM
ukdude's Avatar
Default Re tinny rattle
Hi - it is more like an empty tin rattle but only when blipping the throttle through a short range of revs - around 1500 rpm.
Old 01-29-2015, 12:53 PM
Lose heat shield by the manifold?
ukdude (01-29-2015)
Old 01-30-2015, 10:10 AM
ukdude's Avatar
Default Tinny rattle development
Hi. The tinny rattle at the rear of the engine has now developed into a more sinister sounding solid chatter - on the overrun only. The front end has recently had all the chain tensioners etc renewed to the metal spec. and the full correct kit used as far as I know.
Any ideas would be most appreciated.
Old 02-25-2015, 11:02 PM
ukdude's Avatar
Smile Tinny rattle development
Tinny rattle at rear of engine now diagnosed and cured - it was a right bank catalyst breaking down and cured for the princely sum of 207 Euros by SRS at Cucador - thank you, chaps!And my thanks to the helpful interest of other members.
Old 02-26-2015, 10:40 AM
Gus's Avatar
Gus
Gus is offline
That is a new one!
Old 03-07-2015, 07:38 AM
XK_SL's Avatar
I've got what is probably the exact same sound on the overrun when coming down from 2000 to around 1500 rpm... Chains and tensioners were done recently and I was freaking out that it was them but it seemed odd that it would only occur at a specific rpm. Went underneath and sure enough the rattle appears to be coming from a Cat.
Have to scrape up some cash to sort that out, bit of a killer getting large things like Catalysts shipped over here!
D.K
12-10-2023 02:05 AM
Harry Dredge
09-03-2015 03:04 AM
Harry Dredge
09-02-2015 02:26 PM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Tinny Rattle From Rear of Engine
