Top Wont Go Up Down, Rear Windows???
Old 04-30-2012, 06:28 AM
Bertram Wooster's Avatar
Default Top Wont Go Up Down, Rear Windows???
What Ho
Put new right rear window regulator in yesterday. Went to put top up to cycle. Came up right until lock proceedure and stopped. Wont react, rear windows in down position. No noise of any kind when I push the switch???
Perplexed!!!
Bertie
Old 04-30-2012, 08:26 AM
steveinfrance's Avatar
It may be that there's not enough hydraulic pressure to operate the lock. Check the little Tee handle on the pump is fully clockwise.
What happens if you cycle the top a few times ?
Did you disconnect the battery to change the regulator?
Old 04-30-2012, 08:47 AM
Received 2,183 Likes on 1,355 Posts
reset your side windows. push each button and hold for 5 seconds after it goes all the way up and down
Old 04-30-2012, 09:17 AM
Chaps
I did disconnect the ground terminal while I worked on the car.
I now have no response from the top, either to raise or lower. It appears to be stuck in an almost closed position. I tried opening the pump valve once again to manually ope, but its like the top is not letting the hyd fluid return to the reservouir. Its just locked. Is there a spot to add additional fluid if low? Is there a electric relay that I might have an issue with?
Old 04-30-2012, 09:54 AM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Did Brutal's suggestion work?
If it does not, you will need to manually latch the top to reset the sequence. Open the petcock, and remove the allen wrench mounted in front of the pump. Pop out the plastic plug in the header and manually latch the roof. Then close the petcock
You should be able to cycle it normally after that.
See also www.jagrepair.com for more info.
Old 04-30-2012, 11:10 AM
Since you disc. The batt. Yes you need to retime the windows, and since you got it stuck and out of time since you didnt do that first. Youll need to retime the top now too. Rtime the windows and press and hold for a few minutes the top button without release. This many timwes will restart the top and allow it to retime without doing it manually
WhiteXKR (04-30-2012)
Old 04-30-2012, 09:18 PM
I am perplexed beyond four b and s's.
Well, I am shaken to the quik.
I tried holding down the switch for milleniums, nothing.
I tried using the door switch. Nyet
I do hear clicks from the back but cant isolate.
No top movement, no window movement. Clicks and pips but no real action.
Time to go to the dealer facista.
God help me.
Bertie
Old 04-30-2012, 09:55 PM
if youve reset the door windows, then manually fully close the top and start again with opening with the button, you did fully close the bypass valve right
Old 05-01-2012, 04:46 PM
I gave up and took to the dealer. $$$
Old 05-01-2012, 04:51 PM
berlin1977's Avatar
Bertie set you a message with my cell sounds as if you are having the same types of problems that i went thru. Had fuses , latch malfunction, all due to a repair with a solenoid on the pump. Jim
Old 05-01-2012, 09:01 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
The windows will not go up until the roof is up and locked. Check the fluid and that the petcock is closed. I should also note that it could be out of sequence and that can be remedied by manually opening the roof and then closing electrically.
99xk8guy
06-05-2023 06:28 AM
dsnyder586
04-04-2019 02:38 PM
FrickenJag
09-25-2016 08:00 PM
EZDriver
09-08-2015 09:25 AM
Quick Reply: Top Wont Go Up Down, Rear Windows???
