Water ingress under driver side kick plates
Old 12-16-2014, 07:39 AM
mrobinson's Avatar
Default Water ingress under driver side kick plates
Hi,
I've recently found that there's quite a lot of water coming in underneath the kick plates on the drivers side ( UK 1998 XK8 Coupe ).
Does anybody know where this water is likely to be coming from? I'm guessing there's a blocked drain, but that's a wild stab in the dark.
PS: I had brand new OEM door rubbers installed on both doors last year, if that makes any difference. Also I park facing up-hill, every night.
Old 12-16-2014, 07:50 AM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
On the firewall on both sides under the bonnet, two plastic covers protecting the fuse box and some other goodies, they both have hoses that drain this area. They do come loose and should be held at the top edge by a clip. Have a look see on both sides.
Wayne
The following 2 users liked this post by cjd777:
B o B (12-17-2014), mrobinson (12-16-2014)
Old 12-17-2014, 10:06 AM
mrobinson's Avatar
Does anybody have a photo or a diagram of this? I had a look last night and couldn't see them where I assume they'd be.
Old 12-17-2014, 03:41 PM
michaelh's Avatar
Received 2,291 Likes on 1,503 Posts
Hi mrobinson.
I've taken a couple of shots underneath the aforementioned covers. They're with my phone unfortunately so not the best in the world.
The first pic is of the driver's side (RHD), the second from the passenger's.
The drain tube attaches to the scuttle just behind the bonnet latch, and is held in place by a rubber strap that is part of the moulding. It's easier to see on the second picture. The straps can unhook or simply fail allowing the tube to drop off the scuttle drain. Amazingly, mine haven't yet perished <tempts fate>
The cavities underneath these covers also have a drain hole at the bottom. It's hard to see, and I'd got a bit carried away with the waxoyl and managed to bung both up. The resulting small lakes caused water to drip underneath the dash.
On a separate note, you mention kick plates, which I take to be at the bottom of the door aperture. My son has a Mk2 Golf that was giving a similar problem which we tracked down to failed seal on the plastic door liners. It wasn't at all obvious how the water was getting in until I fired the garden hose at the door. Amazing how much dripped off the back of the door trim and straight over the door seal on to the carpet, so it might be worth checking these. They don't always go back too well after being disturbed.
HTH,
Mike
Attached Thumbnails Water ingress under driver side kick plates-rhstube.jpg   Water ingress under driver side kick plates-lhstube.jpg
The following 2 users liked this post by michaelh:
Lufferman (01-08-2015), mrobinson (12-18-2014)
Old 01-20-2015, 03:52 AM
mrobinson's Avatar
I asked my mechanic to take a look at all the drains and flush them out last week. It seems fixed now. Thanks chaps.
mbergen
10-23-2019 10:26 PM
PMKimpton
08-03-2019 08:22 PM
Dicque
09-19-2015 12:53 PM
SteveSheldon
UK & Eire
09-08-2015 11:22 AM
Dallas XK8
09-03-2015 12:17 PM
Quick Reply: Water ingress under driver side kick plates
