where is the ICooler Pump?
Old 01-29-2015, 09:07 AM
yyk's Avatar
yyk
yyk is offline
Default where is the ICooler Pump?
I'm blowing the 20 Amp fuse. Been wondering also if there is a relay in the enclosed box in the bulkhead area next to the fuse box. Heard it was the 4th one in towards the engine, but I don't see a separate fuse for it.
I took the Aircleaner box off completely and all I saw was a small connecter snapped into the area next to the shock tower and another a little lower. Saw some pipes off of the IC cooler but no pump next to the horns. Am I looking in the completely wrong area?
Any comments, diagrams or even pics, would be helpful. Cat is a 2000 XKR.
Old 01-29-2015, 09:36 AM
Stumpy's Avatar
The Intercooler pump runs all the time the ignition is on, the engine does not have to be running/started.
The pump is a common failure, with fuse blowing, and many members have had to replace them.
You can read this thread https://www.jaguarforums.com/forum/x...acement-85645/
The pump is fitted under the airbox, close to and above the alternator.
See this photo:
Old 01-29-2015, 10:04 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
You can go to my page for the wiring diagram for your car.
Gus
www.jagrepair.com
Old 01-29-2015, 03:47 PM
yyk's Avatar
yyk
yyk is offline
Default Where is ICooler Pump Pump
Those hose clamps in your pic, are those the originals? They look like candidates for worm clamp replacements. How did you get those originals off?
And the airbox wire connector. Does it just go to a ground nut and have a branch wire to something else? Looks like it has a small branch wire but I can't tell to where. Is it easy to replace? I broke the clip where it hangs off the airbox. It will stay on it but I'd like a replacement, even if I have to buy the whole wire setup.
04Xjrsteve
05-07-2019 04:06 PM
rocket1lf
09-29-2015 09:16 AM
Paulie710
09-28-2015 03:49 PM
Collector1
09-28-2015 03:52 AM
Quick Reply: where is the ICooler Pump?
