Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
XK8 driveshaft U joint
LinkBack Thread Tools Search this Thread
Old 03-02-2012, 07:49 PM
Default XK8 driveshaft U joint
Been away for a while, just covered up at work. I decided to keep the XK8. At this point I've solved the nagging problems and it's a joy to drive....when it's running right.
But it's time for some maintenance and I've got a problem that hopefully I'm not the first to encounter.
The rear drive shaft U joint needs replacing. This is probably a Ford part (just a guess since Ford owned Jag in 1998 and there are other Ford parts on the car).
But of course the local dealer wants to sell me a complete drive shaft assembly for $2,100 plus freight and tax. And all I really need is a U joint. But can't find that part on-line of course.
Has anyone else been here before me and discovered what U joint fits?
Thanks again for all of your help. I couldn't have solved the prior problems without the assitance of many of you. It's appreciated.
Many thanks,
Oldfart
__________________
OldFart
1998 XK8 Coupe
Old 03-02-2012, 08:51 PM
Skid Mark's Avatar
Is the dealer that told you it was the U joints the same one that wants to sell you the drive shaft?
xk8 u joint | eBay
__________________
2002 XK8 (defensive parking)
82,000 miles
Old 03-02-2012, 10:05 PM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
Send a message via Skype™ to Gus
Use this link http://jagrepair.com/images/AutoRepa...to%20%2705.pdf go to page 11 in the center column item #2 then look to the right column on the top of the page you will see the breakdown. I hope this helps.
How did you make out with the stalling?
__________________
Gus
www.jagrepair.com
XK8 1999 130,000mi K&N Filter, S-Type 2000 3.0 120,000mi K&N Filter
“If you can't dazzle them with brilliance, baffle them with bullshit.”― W.C. Fields
Insanity: doing the same thing over and over again and expecting different results.-Albert Einstein
“I fear the day that technology will surpass our human interaction. The world will have a generation of IDIOTS.” – Albert Einstein
The Following User Says Thank You to Gus For This Useful Post:
budbrown2 (10-08-2014)
Old 03-04-2012, 12:06 AM
H20boy's Avatar
hope not too much of a tangent, but are there serviceable grease nipples on those u-joints on the drive shaft?
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 03-04-2012, 08:58 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
Yes!
__________________
Gus
www.jagrepair.com
Old 03-04-2012, 09:08 AM
JgaXkr's Avatar
I just went onto JEPC & looked up the prop shaft & they do not list the universal joints. The Ebay link for the joints are for the half shafts, the part number JLM01388 is a valid part number but goes to half shaft application for many Jaguars. Your best bet may be to go to a machine shop that does truck repairs or drive shafts. They could match it up of modify the shaft to accept a replacement. If you do find a replacement joint that would be great for all of us.
__________________
2000 XKR Kenne Bell Twin Screw, 4.2 eng., ported cyl heads, reground cams, Killer Chiller cust cooling system , 3.77 LSD , Recaro seats, Arden Hardtop, custom carbon fiber interior, rear seat delete, roll bar, back up camera-DVD player-Ipod interface all on nav screen, real gauge, Arden Sportline wheels, Alcon calipers with 410mm front rotors, Paragon Performance front bumper, Arden rear bumper & side sills, Arden exh. with Nameless track pipes Ultra Racing under carriage braces & rear sway bar.
Old 03-04-2012, 10:07 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
I had both of my “U” joints on one side replaced and I did not get the assembly. I wish I had the paperwork to give you the part number but what I can tell you is that they are available.
__________________
Gus
www.jagrepair.com
Old 03-04-2012, 10:34 AM
Spurlee's Avatar
Quote:
Yes, and somewhat difficult to get to as a set. They are offset 180 degrees from one another and when I can reach one, access to the other is blocked. If you were on a full lift I guess you could rotate the wheels to get at them but I am stuck on the ground so it is a pain.
__________________
Scott
2000 XK8 Convertable (90+K): Daily Driver winter and summer. Triple Black, 3-Gauge. Remote Top & RealGauge. Stainless hydraulic top lines, pressure reduction valve. Rebuilt throttle body and ABS controller.
2000 Corvette (110+K): Torch Red/Black/Black. 6 Speed. Rock solid and trouble free.
2003 Harley Davidson Deuce: Mid range cam, remapped EFI, pipes, dyno-tuned - waaay too loud for most.
Old 03-04-2012, 10:57 AM
JgaXkr's Avatar
The joints you are mentioning are the half shafts, they have always been servicable. I thought he was looking for the drive shaft/prop shaft joints.
__________________
Old 03-04-2012, 11:22 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
When he said the “rear drive shaft “U” joint” I felt he was talking about the half shafts and that is why I provided a parts listing to see if that is what we were talking about. I am unable to find a parts listing for the main drive shaft from the trans to the rear differential.
__________________
Gus
www.jagrepair.com
Old 03-04-2012, 11:32 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
This is what I did find
__________________
Gus
www.jagrepair.com
Old 03-05-2012, 08:11 AM
The Coupe's Avatar
Fart,
I'm glad to hear that your long nightmare from last fall seems to be over (knock on wood..tap, tap).
Please tell us more about how you got everything resolved. Maybe find that old thread and update it (unless you've already done that...I could have missed it). I remember you had such a multi-layered mystery on your hands, with not much local assistance...it would help us all if you told us what the problem(s) actually turned out to be.
__________________
1997 Jaguar XK8 Coupe, Sherwood Green / Coffee
- According to Jaguar Heritage, my car was assembled on 13 May 1996, in a pre-volume build group of 111 cars for management evaluation and photography.
- This group of "4P" cars featured all options and represented all international markets. The first true customer XK8 was produced 23 days later.
- The engine was assembled on 15 March 1996, in the first two weeks of AJ26 4.0 engine production.
- 125,000 miles, modified and growling nicely!
Old 03-05-2012, 02:36 PM
H20boy's Avatar
I had the car up this weekend, and couldn't find any zero fittings on the propshatft u-joint. Well at least I didn't miss that one by mistake...half shafts were lubed a few months ago myself.
__________________
My Jag Galleries
Go Texas Tech!
The Following User Says Thank You to H20boy For This Useful Post:
Gus (03-05-2012)
Old 03-06-2012, 05:09 PM
daddyo007's Avatar
Just to embellish what Gus provided. The drive shaft has a jurid coupler. There are no u joints on the drive shaft they are rather on the half axle's, off the rear end to the tire spindles.
They should have grease fittings. This comes to many a surprise that these are even there. You have to know they are there just to spot them. Easy to grease if the whole rear end is in the air. This way you can rotate the tires to get your gun on them.
Hope this helps. I have spoken to my Jag guy and he said the jurid couplers rarely fail.
Old 03-06-2012, 06:40 PM
Skid Mark's Avatar
Not trying to disagree with you M-M-Max(Headroom), but there is a U-joint coupling between the aft end of the drive shaft and the flange that attaches to the differential. There is a jurid in the same location on the XJ series.
Paranoimia (feat. Max Headroom) - Art Of Noise - YouTube
__________________
82,000 miles
The Following User Says Thank You to Skid Mark For This Useful Post:
Gus (03-06-2012)
Old 03-06-2012, 11:52 PM
plums's Avatar
There is also a u-joint showing in the diagram plain as day at the front end of the propeller shaft.
You can also hit the grease nipples while flat on the ground. Just figure out where the nipples are, mark on the outside of the tire, jockey the car until the nipples are facing the direction you need, lie down in the dirt, hit the nipples.
BTW, not all cars have the nipples at 180* opposites. Some have them on the same face. Just luck of the draw on assembly.
Old 03-07-2012, 07:26 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
In my younger years when universal joints were not equipped with a grease fitting we would drill and tap the U joints, ball joints and apply grease to prevent a failure. Without seeing the propshaft up close I am assuming the U joint is without a fitting and not replaceable. What are the feelings of the forum about installing a fitting?
__________________
Gus
www.jagrepair.com
Old 03-07-2012, 07:29 AM
daddyo007's Avatar
Thus the reason for Max Headroom. speaking with out making sense sometimes. I recall my thinking of why I thought there was not a u joint on the prop shaft. "MY" noises weren't coming from the front but the rear. I was speaking from my experience and not fully looking at the drawing as a whole. Thus the incorrect comment.
Enjoyed the video. I needed it this morning, already!
The Following User Says Thank You to daddyo007 For This Useful Post:
Gus (03-07-2012)
Old 03-07-2012, 08:42 AM
GGG GGG is offline
Photobucket
Send a message via Skype™ to GGG
Quote:
Gus,
Been looking for a chance to use this one for some time -
Jaguar don't list a propshaft UJ as a separate part. They have the propshaft as a non-serviceable item!
Haven't had the need to closely inspect mine but it must be the standard UJ design secured with circlips and not peened in?
__________________
2007 XK 4.2 Coupe
Old 03-07-2012, 10:07 AM
Gus's Avatar
Gus Gus is offline
gus@jagrepair.com
I will look at it and let you know.
Quote:
Originally Posted by GGG View Post
Gus,
__________________
Gus
www.jagrepair.com
Tags
2003, 2006, assembly, differential, drive, ford, jaguar, joints, maui, problems, rear, shaft, ujs, xk8, xkr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
