top latch
Received 9,005 Likes
Received 6,249 Likes
Here is Gus's convertible top page
JagRepair.com - Jaguar Repair Information Resource
Follow Norris' advice. Check fluid level and petcock. To get to the pump remove the panel covering the CD changer in the boot.
Check the fluid level and that the petcock at the tank is closed (clockwise) as suggested earlier. Be sure the fluid level is good and the petcock is closed and if the roof does not operate do not panic you may have confused the system attempting to open and close the roof. Let us know what you find.
RaceDiagnostics
09-13-2015 02:22 AM
