An XK8 Project (1999MY)
Old 12-22-2014, 07:37 AM
Rezzz's Avatar
Default Rear suspension In
Finally after some playing about the rear suspension system is back in now to finish mounting the shocks, brakes etc. The entire bottom side of the Jags been finished in POR15
Attached Thumbnails An XK8 Project (1999MY)-img_4757.jpg   An XK8 Project (1999MY)-img_4758.jpg   An XK8 Project (1999MY)-img_4759.jpg   An XK8 Project (1999MY)-img_4761.jpg   An XK8 Project (1999MY)-img_4633.jpg
The following 6 users liked this post by Rezzz:
ccfulton (12-22-2014), franksm (12-22-2014), GalaxyDriver (02-20-2015), Junkyardjohn (02-07-2019), michaelh (12-22-2014), oyster (01-02-2015) and 1 others liked this post. (Show less...)
  #62
Old 12-22-2014, 08:22 AM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
WOW, There are those of us that would call this a thing of beauty. Well done, detail is hard to hide.
Wayne
  #63
Old 01-02-2015, 02:30 PM
Rezzz's Avatar
Default Still Plugging Away
Moving onto the front suspension now that the rear has been completed
Attached Thumbnails An XK8 Project (1999MY)-image7.jpeg   An XK8 Project (1999MY)-image6.jpeg   An XK8 Project (1999MY)-image1.jpeg   An XK8 Project (1999MY)-image5.jpeg
The following 4 users liked this post by Rezzz:
ccfulton (01-03-2015), GalaxyDriver (02-20-2015), Jag#4 (01-02-2015), michaelh (01-03-2015)
  #64
Old 01-02-2015, 04:37 PM
Jag#4's Avatar
Can't wait to see this next stage of the project. What I have seen so far is amazing!
Rezzz (01-02-2015)
  #65
Old 01-05-2015, 06:57 AM
Rezzz's Avatar
Default Trans In
Ok so the trans went in on the weekend and I was able to install the new combination dip stick - fill tube from 5HP24 Dip Stick
Attached Thumbnails An XK8 Project (1999MY)-10885464_10152950099105140_5799366998371724570_n.jpg   An XK8 Project (1999MY)-10898146_10152950099270140_2548904452070322300_n.jpg   An XK8 Project (1999MY)-10906177_10152950099385140_2091818409368615952_n.jpg   An XK8 Project (1999MY)-10404132_10152950099730140_8726444682339198799_n.jpg   An XK8 Project (1999MY)-10422555_10152950099995140_7108321382741674920_n.jpg
The following 2 users liked this post by Rezzz:
cjd777 (01-05-2015), oyster (01-05-2015)
  #66
Old 02-04-2015, 06:42 AM
johns55's Avatar
How's everything going with the rebuild? I'm in the middle of mine and love looking at your pictures.
  #67
Old 02-09-2015, 11:27 AM
Rezzz's Avatar
It was stalled for a bit. I have been busy since the New Year but going to start up again this week. I'll post some additional pics. How about you?
  #68
Old 02-09-2015, 10:10 PM
skeena river rover's Avatar
I am very impressed! Keep up the fantastic work! keep the pictures coming!
Cheers from the West Coast!
  #69
Old 02-11-2015, 10:15 AM
JagSlave's Avatar
Have you considered upgrading the brakes to the larger XKR rotors and calipers? It can be installed with just a bit of cutting of the edges of the rotor shield to make clearance.
Rezzz (02-15-2015)
  #70
Old 02-20-2015, 09:58 AM
Rezzz's Avatar
Took a break from working on the mechanics of the XK and decided to start on some interior work. Replaced the passengers side seat leather cover, next will be the drives and working on console parts.
Attached Thumbnails An XK8 Project (1999MY)-10996120_10153083524945140_4935401143476078491_n.jpg   An XK8 Project (1999MY)-10991254_10153083525020140_5624439401492109377_n.jpg   An XK8 Project (1999MY)-11014993_10153083524740140_3008691682122235391_n.jpg   An XK8 Project (1999MY)-10387317_10153083524615140_1037809728783037836_n.jpg
  #71
Old 02-22-2015, 10:06 PM
JagSlave's Avatar
Beautiful job. Did you recover the seats yourself? If so, did you have any guidance? My drivers seat on my 97 XK8 conv is in tatters. Thanks!
Rezzz (02-23-2015)
  #72
Old 02-23-2015, 10:57 AM
Rezzz's Avatar
Thanks. Yes I did them. This is not a difficult task. The seat covers come from Convertible Tops, Headliners, Convertible Top Parts, and OEM Seat Covers , there are a number of posts on the forum on this, fit is excellent in my opinion. Just be careful if you in colder climate and attempting this work the plastic fitting, covers, etc become brittle. I have a fully heated garage so it all worked well.
JagSlave (03-04-2021)
  #73
Old 02-26-2015, 07:44 PM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
Differential bearings, housing O-rings, pinion head and tail bearings, pinion oil seal and case breather all changed out. New drain and plug drilled and tapped into the base as well
Out of curiosity, did you happen to notice the diameter of the ring gear?
And did you happen to notice if there were abnormalities in the gear marking pattern?
For example, favouring the heel?
  #74
Old 03-03-2015, 10:51 AM
Rezzz's Avatar
I'm sorry I did not
  #75
Old 03-10-2015, 02:46 PM
Rezzz's Avatar
Default Still At it
Rear suspension is complete, rear brakes completed. New valve cover seals and plugs in. Throttle body on this weekend and starting the Cat up for a little spin around the lot most of the snow starting to melt off. Then back on the hoist for the front suspension removal and re-furbish. Body Shop hopefully by first week of April. Fingers and toes crossed.
Attached Thumbnails An XK8 Project (1999MY)-997026_10153116759320140_658525384461697212_n.jpg   An XK8 Project (1999MY)-11034286_10153116759390140_7196722395176684005_n.jpg   An XK8 Project (1999MY)-11059930_10153116759480140_3624788022384844139_n.jpg   An XK8 Project (1999MY)-11042679_10153116759540140_8950442011670069388_n.jpg
  #76
Old 03-11-2015, 11:22 AM
daddyo007's Avatar
Keep up the good work maybe a little inspiration for you! Spring is coming!
Just a word about the aluminum cooling tower. I could not keep the cap sealed, so I ended up using the original cap off the plastic tower, no leaks.
I also insulated the fuel line right behind the aluminum tower. That tower gets incredibly hot.
This engine shot was before I changed the cooling tower so you cannot see the insulation on the Fuel line. http://www.summitracing.com/parts/TAY-2575/
I had my seats recovered. The photo appears to show the leathers is a little loose. When mine were covered we added extra foam to take up the "baggy" cover. We did this because of the original foam compressing over years of use. Mainly on the wear area's center seat and center back and head. Just an observation. I do not mean to imply any negative vibes!
Attached Thumbnails An XK8 Project (1999MY)-dcp00647.jpg   An XK8 Project (1999MY)-dcp00656.jpg   An XK8 Project (1999MY)-dcp00654.jpg
Rezzz (03-12-2015)
  #77
Old 03-12-2015, 07:09 AM
Rezzz's Avatar
No negative vibs taken, all good comments. I noticed that as well and will add some foam. Not sure what to add what did you? Unfortunately I threw out the old cap when I was making some room and have learned early on not to do that any longer. I am keeping everything to the bitter end now. Gas shield I will order today. Your Cat looks great!!!
  #78
Old 03-13-2015, 03:31 PM
daddyo007's Avatar
Upholstery foam is best. If you can find a small shop get some pieces of 1/4"/6mm; 3/8"/9mm; and 1/2"/12mm. It took us several tries to get it right. The key to it was to not stress the cinch points to the point that the new covers might start to prematurely rip. It was one of those moments when you know when to much is to much. Its kind of like when you are cutting something with a knife and you draw the blade towards you and just before it slips and slices you wide open you wise up and stop knowing you should.
You might be able to just grab at the leather and pull it out you might get a feel of how much foam you should add.
If memory serves me right we added the foam to the surfaces and not on any of the edges. The edge seams of the leather cover should still be at the edges of the seat and back form.
Hope all this makes sense!
Rezzz (03-17-2015)
  #79
Old 03-16-2015, 09:50 PM
johns55's Avatar
You're getting to the body shop before me I'm waiting for a new pinion flange for the diff. Then the rear end will go back in. I'm replacing the timing chains and primary tensioners (already did the secondary).
How did it drive when you took it out before the front end work?
  #80
Old 03-17-2015, 11:53 AM
Rezzz's Avatar
It drove well thanks. Good to see I'm not the only one investing time and money into one of these older ladies. I didn't have to do the chains and tensioners the motor had been replaced under an extended warranty in 2002 with new crate engine believe it or not. Best of luck to you that work I would imagine is not easily completed
Quick Reply: An XK8 Project (1999MY)
