Xkr 2001
Old 04-16-2014, 01:55 PM
Dude's Avatar
Default Xkr 2001
When lifting up door handle to open door (outside), the window automatically moves down about 1/2 inch for rag top clearance. Just started to malfunction as each time the handle is moved up the window automatically moves down about 3 inches? Even with the door open a can continue to pull up on handle each time the window will move down on both doors? Any suggestions as to why this started and what is best fix?
Old 04-16-2014, 01:58 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Charge your battery. Then reset the windows according to the Owner's manual. If it happens again after that, replace the battery. This is usually the first sign of a weak battery.
Old 04-16-2014, 02:12 PM
Dude's Avatar
Default 2001 xkr
Will do, thank you for the info. Nice pix of your XKR.
Old 04-16-2014, 03:01 PM
GGG is online now
Received 16,789 Likes on 12,163 Posts
When lifting up door handle to open door (outside), the window automatically moves down about 1/2 inch for rag top clearance.......
Even though it is now RESOLVED, I've moved your thread from General Tech Help to XK8/XKR forum.
Please post model-specific questions in the tech forum.
toronadomike
08-07-2022 03:41 PM
picard
10-12-2015 11:56 AM
Poet
10-06-2015 09:40 PM
hhv00586
09-18-2015 08:59 AM
skadmiri1
09-09-2015 11:27 AM
Quick Reply: Xkr 2001
