2001 XK8 4.0 NA Oil in the Spark Plug Wells
Old 04-19-2014, 01:47 PM
Kalahari's Avatar
Question 2001 XK8 4.0 NA Oil in the Spark Plug Wells
The mother in laws Jag developed a bad miss the other day with a CEL. Going through the codes it looks like a miss fire. Since these were the original plugs I started with them. To my surprise there was a considerable amount of oil in the spark plug wells. Is this from a leaky valve cover gasket?
Thanks, in advance!
Old 04-19-2014, 01:59 PM
Paul Pavlik's Avatar
Thanks, in advance!
Probably. The O-Ring seals under the center of the Valve Cover need to be replaced.
The gasket set FEL-PRO Part # VS50724R or
VICTOR REINZ Part # VS50397 includes all necessary seals.
Old 04-19-2014, 02:35 PM
Kalahari's Avatar
Is that the right Fel-Pro number? Looks like Ford/Lincon 3.9l.
Old 04-19-2014, 05:35 PM
Yes, AJ27 (1999-2002) XK8s use the same Gaskets. The Lincoln LS V8 Engine is a version of the Jaguar Unit.
ericrucker (09-19-2023)
Old 04-19-2014, 05:44 PM
mike66's Avatar
Misfires are a common sign of coil failure as well. What codes did you get? If you post the codes or know which cylinders are bad, swap the coil with a good cylinder and see if the misfire follows the coil from the bad cylinder(s). And yes, as Paul said, time for new gaskets.
Old 04-23-2014, 07:48 PM
Kalahari's Avatar
One side done and new battery installed. Now I'm getting an ABS failure as well as :
P0357 - Ignition Coil G Primary / Secondary Circuit
P1000 - ODB System not ready (if I remember correctly)
P1649 - FCCP Monitoring Flash Memory Malfunction
I was getting a miss in cylinder 6 and swapped coils with cylinder 7. Initially it ran fine but shortly developed a miss.
Sounds like I need at least one new coil. Are the Denso coils significantly better than what I can get at the local parts store?
Old 04-24-2014, 08:10 PM
Kalahari's Avatar
Bump...
toronadomike
08-07-2022 03:41 PM
kelliott
05-31-2022 05:26 PM
Gus
10-15-2019 12:29 PM
Charlene n John
09-28-2015 06:01 AM
pnwrs2000
09-03-2015 11:55 AM
Quick Reply: 2001 XK8 4.0 NA Oil in the Spark Plug Wells
