2002 keys - are they a chip key?
People have been able to find LockSmiths that are capable of grinding the Tibbe Key Blank, but cannot program it to the car; I came across someone in Yakima I think, which is ~1.5 hrs from where I live. This is still useful if you only have one Black Head Master Key like myself, as the copy of the key without the chip programmed will still unlock the door and trunk locks, but it will not start the car until programmed by Jaguar, or a garage with the proper equipment. This allows you to have a spare key to gain access to the vehicle in case you lock your 'real coded key' inside the cockpit or trunk; even worse if the car is running. It happens, just check the post page, a member currently has their keys locked in the trunk with the battery disconnected.
You can also get another key fob/remote. These are very inexpensive on ebay and there is a DIY procedure on this forum for programming them to your car (the transponder key is not so easily programmed). The fob will allow you to gain access to the car and the trunk and also to disarm the security system.
I put an extra key in a 'hide-a-key' box wrapped in foam and tucked it up in a shield under the back of the car.
My wife called one day and said she stopped off on her way to work to get a tire repaired for a leak (nail in the road, now in the tire). She was about 40 miles away and wanted to know if I could DROP EVERYTHING and bring a spare key??? I asked why and she said the kid repairing the tire locked the keys in the car!!!!!!!!!!!!! I did not even bother asking how.
I remembered the hide-a-key and told her to give the phone to the kid. I told him to lay on the ground behind the car and reach up........................
He said "I found it!!!!!".
He later told my wife "THANKS-YOU SAVED MY JOB".(plus I did not have to drive all over creation to deliver a key)
If you buy a cheap key for XJ40 or X300 and have the correct cuts made, the key can never start the engine but it will get you into the car. It can never be configured to the car because it lacks the transponder.
If you have a 1997 X100 and live in the U.S. then you don't have to worry about transponders.
Something to think about???
bob
bob
powell (09-02-2020)
Not the Ford part, but this one works fine on my 2001 XK8:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Check the FCC code on the original fob e.g. CWTWB1U322 and see if it matches.
Burnham (10-19-2016)
JayJagJay
10-24-2016 09:11 PM
JayJagJay
09-30-2016 10:36 PM
