front shock mounts stuck
Old 02-01-2020, 02:25 PM
stevepaa's Avatar
Default front shock mounts stuck
I replaced all shocks and front shock mounts 5 years ago. But I could not get camber correct as my ride height is low.
So I am replacing all springs, isolators and mounts to try to get my car to correct height. Did the rears and I need to order some packers.
Went to front and after compressing spring I cannot get shock mount off the shock shaft.
Old 02-01-2020, 02:48 PM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
I know it's a silly question, did you get both nuts off the shock bolt. They have two, one is a locking nut on some cars, maybe not yours.
Of course let us know what you find out, It does look a little cocked, a bigger hammer but don't know if the foam would stand up too much beating.
Old 02-01-2020, 03:00 PM
stevepaa's Avatar
Only one nut on end of shaft holding mount on.
Old 02-01-2020, 03:17 PM
stevepaa's Avatar
I am using kroil and twisting the shaft. maybe in time it will come loose
Old 02-01-2020, 06:33 PM
stevepaa's Avatar
Jaguar instructions actually use the spring to push off the mount in their apparatus.
I may try releasing the spring tension tomorrow slowly.
Old 02-02-2020, 02:38 PM
stevepaa's Avatar
I used a big gear puller and it came off.
cjd777 (02-02-2020)
Old 02-02-2020, 06:24 PM
stevepaa's Avatar
new spring and old spring
Old 02-02-2020, 06:32 PM
cjd777's Avatar
That is a lot, no wonder you were low.
I have to ask. Why no jack stands? I understand if in mud, I'm trying to get a Spirit out of the mud and mo way would I trust a jack stand on the ground, we are getting rain every few days. The tire rims were under ground, been there a while.
Good idea on the puller.
Old 02-02-2020, 07:11 PM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
I don't see a collapsed old spring. I see an extra coil on the new one making the difference.
Anybody know what the unsprung height should be on a spring with that color code?
crbass (02-02-2020)
Old 02-02-2020, 10:06 PM
stevepaa's Avatar
I used the wood under the front frame piece and a jack stand under the A arm when needed. You can just see one leg of the jack stand
Old 02-02-2020, 10:28 PM
EnjoyEverySandwich's Avatar
That happened to me, too. I ended up sawzalling the shock shaft. I tried releasing the spring first, but no luck. I did not enjoy what I did.
Old 02-03-2020, 09:48 AM
Mad Hatter's Avatar
I did the same thing.
Took it to a shop with a much better spring compressor and they managed to compress the spring much further than i could and then tapped the upper shock mount from below with a hammer gently and it came off.
I had tried to use the spring to remove the upper shock mount as well and even the spring wasn't strong enough to unlodge it.
mhminnich
03-09-2022 01:57 PM
EnjoyEverySandwich
10-01-2019 09:16 AM
StuG
08-30-2016 04:49 AM
Johnken
06-01-2015 10:46 PM
Quick Reply: front shock mounts stuck
