Cable Routing Help Needed -XK8 Conv
'06 XK8 Left-Hand Drive
I need to route a cable with a 1.5cm connector from the passenger compartment to the boot/trunk. I have the jump seat and fuel tank shield removed. There are several wire bundles that make this journey, but I haven't found a path to follow.
An insight will be appreciated.
Thanks!
Thanks!
DrOrb (10-19-2016)
Put your top down. Then remove the cover of the fuel tank in the boot/trunk, simply pulls off. Then look on the right hand side in the boot/trunk you should see a bit of day light. Find a long thin cane push it through till it appears on the inside of the car. Tape your wires to that. Pull it back through. Jobs a good un.
http://www.jaguarforum.com/showthread.php?t=75123&
DrOrb (10-19-2016)
patpin
08-31-2016 01:33 PM
