Convertible top - blowing fuses
Have a 2004 Xkr that is blowing the 40 amp fuse when operating the top. Rear windows will go down and back up, but the fuse will snap instantly with no indication of anything even trying to operate. Pressure relief vavle was installed two years ago. Has anyone had to trouble shoot this kind of problem?
I hope this is not the case with you but when I started blowing fuses when hitting the roof button, it turned out the be a bad pump motor. If you look back through some of the threads I posted when this happened to me, there were posts by others that included ways of trying to isolate the problem before assuming it is the pump--do a search for those posts.
Doug
Doug
filoli1993 (08-11-2012)
If you unplug the 2 prong black wire/white wire connector and it no longer blows the fuse, you almost certainly have a bad pump.
There are a number of used ones on ebay at the moment at decent prices: jaguar xk8 convertible pump | eBay
A new one lists for $6900 !!! ... probably a non-starter.
Doug
This has got to be faulty information. I think when I and the dealer were searching around for a replacement pump, an OEM from Jaguar was about $2,000. This is still quite a ridiculous price but it was covered by warranty. If it was coming out of my pocket the better way to go would be to find someone that repairs electric motors.
Doug
Doug
2005 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
Here is my source:
Doug
99xk8guy
06-05-2023 06:28 AM
OkieTim
09-08-2015 04:48 PM
