Rear Light
Old 08-22-2012, 12:04 PM
Kertel's Avatar
Default Rear Light
I have a 2003 XK8. The warning message "check rear lights" came on. My right rear light (next to brake light) was not working. I replaced the bulb with no luck. Followed owners manual instructions and checked the fuses. Fuse #19 was burned out, so I replaced from the color-coded fuses included with the car. That fuse burned out in a few seconds after restarting the car. Any thoughts on what might be causing the issue?
Old 08-22-2012, 02:38 PM
MRomanik's Avatar
I had a similar problem but didn't burn out fuses. I did this fix for the ground issue.
File Type: pdf
Kertel (08-27-2012)
Old 08-22-2012, 03:23 PM
WhiteXKR's Avatar
Received 2,980 Likes on 2,123 Posts
Inspect the blue wire from the lamp housing to the fusebox for damage and a possible short to the chassis. Also check the lamp socket for any broken metal bits.
Kertel (08-27-2012)
Old 08-23-2012, 08:03 AM
Kertel's Avatar
Default Rear Light
WhiteXKR & MRomanik, Thanks for the replies and advice. I will attempt these fixes this evening.
Old 08-27-2012, 09:18 AM
Kertel's Avatar
Default Rear Light
Was unable to find a solution to the rear light issue I was having despite great suggestions from WhiteXKR and MRomanik. Can anyone recommend a repair facility in Southwest CT (Fairfield County) for Jaguar wiring issues?
99xk8guy
06-05-2023 06:28 AM
mbergen
10-23-2019 10:26 PM
King Charles
09-03-2015 12:40 AM
OkieTim
09-02-2015 12:48 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Rear Light
