Fitting a steering wheel growler badge
Has anyone managed to fit (to an X100) a centrally positioned Jaguar growler badge to the steering wheel? I have always felt that the otherwise attractive steering wheel (wood and leather) was deficient in not having a nice badge. There is, of course, the growler 'imprint', but it is not central to the steering wheel.
I realise that it is not a good idea to mess with the airbag. But is it possible - very, very carefully - to remove the airbag COVER, in order to attach a central growler badge (and then re-install) ?
Alternatively, is it feasible to transfer from an XJ350 steering wheel the airbag cover? It would need to be from a 15 inch diameter wheel, of course. The airbag cover for that model DOES have an attractively recessed (green) growler badge. I don't have ready access to an XJ350 in Adelaide (South Australia), so I am unable to check the measurements. Is there anyone who could check those measurements?
Ideally, I would fit to the centre of the airbag cover a green 4.0 litre growler badge identical to the one on the bonnet/hood of my 2001 XK8. This would give it the look of a traditional "horn push".
I believe it's also illegal to tamper with them, that being said it's your car do what you want, just be sure should you sell it that whatever has been done is reversed so the next owner can make their own decisions!
BodmanRae (12-04-2016)
I added a growler using an old grille badge. Ground the mounting pins off flattened the slight curve of the badge and silicone it to the air bag cover, no disassembly required.
https://cimg5.ibsrv.net/gimg/www.jag...c673353801.jpg
Steering Wheel Growler Badge
That airbag wont fit 1999-2006 steering wheels. It's flatter up top, doesn't have the same arch. Really hard to tell, only when you have them in your hand next to each other does it become obvious. Plus, it's the older single stage airbag---likely will trip airbag light
toaster (12-06-2016)
You do not have to remove anything. You can get the growler on E-Bay, then as I stated earlier, grind off the mounting tabs, place a towel or something soft on the face side and gently press in the vice. Doesn't take much just has a slight curve to it. Then wipe the area with embossed growler with isopropyl alcohol, put s button of silicone on the back of the badge and press in place, covering the embossed growler, make sure it doesn't slide down. a piece of tape will hold it until dry.
