Headlight Horizontal Alignment - 2002 XKR
My headlights were aimed so low that I wondered about the extensive front suspension maintenance the previous own claimed to have had done.
I combed the forums and found how easy it is to adjust vertical headlight alignment in a thread from 2009. What I cannot find in forums or manuals is where to look for the adjustment for horizontal alignment. (These are standard projector low (dipped) beams, not HID.)
Much obliged for any help!
When you say aimed so low, I think vertical adjustment. Do you need to point them left right along the horizontal ?
Here's what I found on my 98:
Yes there is a separate horz adjustment, I never used it.
Low and high beam adjustments are inseparable. They adjust together for vertical. You are stuck maximizing both, not a perfect set up for my low beam coverage. I did spend the $50 for those "extra" bright lights - waste of money. Barely discern the difference.
Different years have different lights, so I can not add any more for your 2002.
BINGO!
Thanks, Oyster! I was able to get to the adjustment screw on the left side. There seems to be a dull white cylindrical plastic cover over the whole adjustment assembly on the right side, but now I know what I'm trying to access. You've given me exactly what I needed. This forum is amazing...
