How to adapt the Passenger seat to 8 way
Is there a easy way to adapt the right side front seat from the (4 or 6 way) to a 8 way adjustable like the driver's (Left)? car is 2003 XK8 Coupe. Perhaps changing the seat base? I don't know what the difference is but the addition adjustment would be worth extra effort and reasonable cost. What mechanical and electronic changes would be required? Suggestions please?
Best of luck, keep us posted.
kstevusa (05-27-2016)
Thanks for replies and, yes, the right side seat control switch is different. All available positions work plus heater also. . The left side has fore & aft, front cushion up & down and rear cushion up & down. The Right front control switch has only fore & aft. No movement on switch to indicate the control could control the other motors if they were present. Perhaps the left frame lower mount and switch assembly would attached to the existing seat back and bottom cushion? any ideas on this?
kstevusa (05-31-2016)
My 1998 passenger seat also only goes back and forth with no vertical adjustment. Is this normal or is it broken?
Also, the drivers side moves vertically but I have not figured out how to raise just the front or rear part of the seat to change the tilt of the cushion. I presumed that with motors at the front and rear, they would be independently adjustable to allow tilt but both seem to operate in unison.
Andy
Andy
As I've told Mrs G., riding in my car is a privilege and not a right.
Andy
Andy
2001 was the first year that the Driver's Seat had separate up-down functions on the front and rear of the seat bottom.
clivedavies
04-07-2016 10:21 PM
joejag05
04-04-2016 09:17 PM
FS[MidWest]: 2003 jaguar x-type black
raze
04-02-2016 12:13 PM
dsnyder586
03-30-2016 09:47 AM
