Supercharger case bolt torque values
Old 04-24-2017, 10:23 AM
mkrion's Avatar
Default Supercharger case bolt torque values
I am in the process of rebuilding the supercharger but cannot locate the snout bolt torque values. Does anyone know what they might be?
Mike
Old 04-24-2017, 11:22 AM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
I am guessing that the snout is outlet related. Found these.
Supercharger outlet pipe to charge air cooler intake assembly retaining bolts 21nm (15ftlb)
Supercharger outlet pipe retaining bolts 10nm (7ftlb)
Supercharger retaining bolts 24nm (18ftlb)
Old 04-24-2017, 11:59 AM
mkrion's Avatar
Thanks Rothwell, they relate to attached intake locations, I am looking for the bolt torque values that attach the snout to the front of the supercharger case. Can't seem to locate anything in the JTIS.
Mike
Old 04-25-2017, 12:46 PM
mkrion's Avatar
Thanks again Rothwell, you were on the right track. I located a site that indicated the snout bolts should be 18-24 ft lbs on the eaton superchargers.
Best
Mike
rothwell (04-25-2017)
