Prognosis for my VVT units
Old 05-30-2016, 12:11 AM
Stamford's Avatar
Default Prognosis for my VVT units
About two years ago, maybe more, my VVTs started making a momentary rattle upon cold startups as they fill with oil. Frankly, I'm prepared to live with the brief noise forever, but I wonder what the future might have in store for me. I'd welcome any opinions on whether this minor issue will eventually become one that I actually have to tend to. Thanks!
-John
Old 05-30-2016, 04:12 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
While there has been lots of discussion on VVT rattle and a few reported replaced I cannot remember any negative impact on engine performance. The issue seems to be just the wear related rattle noise. The usual repair for the rattle is moving to a higher weight oil or an oil additive like RESTORE.
How many miles? I would suggest that the VVT noise is a symptom of overall engine condition and might indicate a move to the higher mileage oils and/or higher weight.
Stamford (05-30-2016)
Old 05-30-2016, 04:58 AM
Addicted2boost's Avatar
I would agree with test point about switching to a heavier weight oil but, anytime we had a customer insisting they get 10W-30 conventional oil to help with the same noise, current VVT codes or some other engine noise instead of the specified 5W-30 conventional oil, they usually end up coming back with a CEL on where as they didn't have one before or they didn't get the desired results. VVT's apparently don't like thicker oil. So I personally would try some type of engine oil based cleaner. I can't comment about a VVT replacement fixing your type of noise because no one has been willing to spend the money on a replacement. I've replaced 2 VVT solenoids that that stick out of the valve cover but that's about it.
Old 05-30-2016, 05:31 AM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
I have been using 10W40 for four years with no problems, but my garage never gets below 50 F in winter. I started because of a rear main leak which is now fixed, but I haven't done an oil change yet and will go back to the spec when I do.
Old 05-30-2016, 07:22 PM
Stamford's Avatar
Thanks, all! I did try the heavier oil with no change, so I'm content to live with it until such time........
John
Old 05-31-2016, 04:10 PM
XJ8JR's Avatar
I too have had this issue for a few years. Tried all sorts of different brands and weights of oil with no success. I've grown accustomed to it, but would be interested if anyone ever found a cure (which doesn't involve tearing about the engine).
One thing that did help was to put in a louder sports exhaust. The start up roar will help to drown out the VVT racket.
Old 06-01-2016, 07:04 AM
Stamford's Avatar
Love it – great example of lateral thinking! (I'm at 111,000 almost trouble-free miles.)
Catsgame
08-23-2016 02:37 PM
jaguarVP96
07-02-2016 03:41 PM
orangeblossom
04-20-2016 06:12 AM
jaggedy
04-10-2016 10:07 PM
JessN16
04-06-2016 01:17 AM
Quick Reply: Prognosis for my VVT units
